Mud Terrains
ThickMick
Hey guys,
Long time lurker first time poster. Got an 04 with the daystar 1" top out spacer and after searching the forums realized i can go with up to a 265/70/r17. Sooo I was offered a great deal on a set of destination m/t's in that size though im worried i will have fitment issues since its actually a 31.9 inch tire. What do you think?
Thanks in advance!
I'm almost sure that those will not fit. You would probably need a 3/2 to fit that size tire. I have a 3/2 cornfed and a 1.5 body lift and still scrubing when turning the wheel all the way to one direction with 33" all terrains. You might be able to get away with it if you keep stock rims. anything wider than stock would more than likely make it scrub pretty bad.
i assume you have stock wheels,so the 265/70 should be ok,with the 1 in. lift, but you will probably have to move the inner plastic fender forward & maybe trim the lower tip of bumper, i say that because i ran 31.5 with a 1in. lift, thats all i had to do. they werent mud terrains tho.
I just got home from Discount Tire and put 265/70/17 Yokohoma Geolanders on with stockwheels 10.7 wide 31.8 tall . No lift no spacers. They look, ride and handle great. I went to an open parking lot and did full turns in all directions and no rubbing what so ever. So you should be good. Sorry the pics are bad its raining like crazy here.
My BFG All-Terrains (265/70-17) fit before I had my lift no problems. You should be fine with your 1" boost.
thanks for all the tips and pics guys. yall are too helpful. i ended up getting an even better deal on some nitto terra grapplers which i noticed a lot of folks here run. i'll post up some pictures when they get here
good choice i really like those and are on my top 3 for when its time for new tires again and ill throw on some 33's :)
They would have been fine. I have the Destinations in that size on my 05 SE. Prior to installing my 3/2 there was no rubbing unless you hit a bump while at full lock or if you were backing up at full lock. Looked so good and performed to the extent that I almost didn't install the 3/2. Glad I did though.
