Okie
I have a 2004 2-wheel drive Sport Edition 4 Runner. I went with the Daystar front and rear 2.5" lift kit. Although I just wanted to level the front, I got the front and rear kit (KT09116BK) because it was only $30.00 more at the time I ordered - glad I did. Much to my surprise after having the front spacers installed, my front was 1/8" higher than the rear! You may not think that 1/8" is that much, but you can see it - especially with the forward motion of driving down the road. If you want the Baja Pre-runner look, this is where you want to be. I didn't, so I had the rear coil spacers installed and now it looks correct. 2.5" for the front was too much for my 4 Runner to just level it. 2" for the front would have been good to take away the front raked look.
The ride comfort is great - I cannot tell any difference from when it sat at factory height.
As far as the Spidertrax wheel spacers are concerned, they are awesome. The quality is top notch and the hub centric design gives me a little more sense of security. In my opinion, it totally changes the look of a 4 Runner - much more aggressive. It even makes the factory tires look wider. I would have done this even without the lift kit.
Keep in mind that the info above pertains to my 2004 4 Runner and your results may differ.
Hope this info helps someone out.
