My Rear Bumper Lens Mod
Iron Clad Lou
UPDATE! I FOUND THAT THE LENS WILL TAKE WATER. AS A FIX, I PUT THE SMALL BREATHER CAPS BACK ON AND USED DUCT TAPE TO WRAP AROUND THE PLUG AND THEN WRAPPED DUCT TAPE AROUND THE SOCKET AFTER I PUT IT BACK IN THE LENS. BASICALLY, I WRAPPED THE WHOLE DAMN THING IN DUCT TAPE
ok...here it goes...
lens out
I predrilled the back of the housing with a tiny drill bit then drilled it out with a 1" bit. take your time as this bit chomps in pretty good.
next, because the generic socket did fit in deep enough for my liking, I cut the lip off the lens with a hack saw, filed it down smooth and filed out the hole just a bit so the socket fit in very snug.
I used super bright led 1157R. btw, I got all of these parts from Advance.
here is the socket...you do need to cut the metal clips off...black is ground, yellow and brown are positive.
once the led is put in the socket, I forced the socket in the lens...the fit was nice and snug...no way is it coming out....it will come out for bulb replacement with some effort though...
this harness I made will plug into the wires from the socket and then get spliced into the wires at the tail light
a little tip here, put the rear lens back in the bumper after you get the socket in and you can easily grab the harness to put it through the bottom hole where the tail light is...this pic shows my connections before I put the through the hole.
the connectors I used worked, but after seeing the attached connectors another user posted, I feel his would have been easier to use.
finally, tails back in...parking lights on...
now, I think it looks super...brake lights work as well, but the dont get real bright...additionally, without the parking lights on, when the brakes are applied, the LED's light up quicker than the filament bulbs in the tails...I believe I'm going to try the 7443 LED's in the tails at some point and see how that works...
Lou you do man.
I did this same mod back in late 03 when she was new. I feel like a cave man after reading yours. I think you just set the standard for best low buck mod. Good job!
Colemanfu said:
Lou you do man.
hehe, thanks man...since my 04 is new to me this past july and I joined the board shortly after, I'm just trying to catch up on mods! this board has done a great job with experimenting...it made doing this mod a piece of cake...I just wanted to share my adventures of the mod and do a nice write up with pics to pass it along...
Wow, that looks good, I think I am going to do this, I also would like to put LEDs in the tail lights...
Clocktower07
