NAVI -Back-up DVD data
LukeSKY
I just ripped the data off my 4.2ver navi DVD, and it come out to about 7.57 GB (8,133,681,152 bytes) worth of data.
To reburn it to my back-up dvd, would I need a dual-layer blank dvd?
Is anyone doing this? what media and program are you using?
Thanks!:awais:
I plan to do this with the Lexus nav dvd's. I plan to use a dual layer dvd...the single layer dvd's only hold 4.7 gig. I'm not sure if they will work if you compress the data to fit on a 4.7gig disc...that is if you can compress the data at all ;)
you can't compress data like you can a video or sound file. what you can do though is to use a re-authoring software to 'cut-out' parts of the dvd that you don't need. for example canada and/or a part of the u.s. you rarely visit until you have under 4.7 gigs of data left.
btw, i'm already hearing (from the originator of this thread i believe) that the dual layer dvd copies aren't working in the nav system. this isn't suprising as the laser in the nav systems may not be good enough to penetrate the dual layer copies. the original was not 'burned', they are pressed by machine, making them much easier to read by the laser.
Actually, cutting out parts is one way, there is another way.
If it is video data, and the format is the same as a normal DVD, you can use an open source program called "DVD Shrink". It's freeware. Just do a google search on the name. It will RIP the data from the DVD and compress it automatically so it will fit on a 4.7 gig DVD or let you re-author it.
it is not a video dvd....it is a dual layer 9gb data cd...you can't cut it in 1/2.
I made a .iso image of the dvd and tried to burn it to a blank dual layer dvd....but my toyota threw it up....
haven't had much time to see why .....
the laser's probably not sensitive enough on the denso nav unit to read dual layer discs. dual layer discs has a semi transparent first layer so that the laser can also read through to the second layer behind it while still maintaining enough reflection for the laser to read itself (the first layer) as well. a lot of 'first gen' lasers can't focus on this degraded first layer.
LukeSKY said:
my navi system is the new one.....it is a dual-layer reader...
what do you mean by that? do you mean it reads the stock 9.4GB disc without any problems? the original disc is pressed, as are all legitimate dvds you purchase in the store made from the factory. any dvd player can read these type. even 10 year old ones. this is a completely different process than when you actually 'burn' a dual layer copy with a dvd burner. the '1's' and '0's' (or more precisely the physical pits on the disc) on a pressed dvd are 1000% sharper than a burned dvd. that's why the lasers have trouble with burned copies.
For the 4th Gen Navigations (Camry Nav) I made a Image of the the disc using Nero, and burned it on to a Verbatim DL DVD, with a LG DL DVDR with no problems what so ever.
How I copied.
The image was 7.57 GB, (8,135,803.036) bytes.
I put my orginal away, and just use my "backup"
j0.
Oh I tried cheap media, and my Nav just puked it back... sometimes you get what you pay for.
I just did a backup of my Toyota navigation DVD. version 5.1 the one that came out this January. Did exactly the same thing as Jo..burnt the image to Hardrive. Used DL DVD to burn to and viola. Did not spit it out or anything. Works great. So I know that 3rd GEN navigation systems will read this.
i got mine but it didn't works ... here's the error "Unable to read data. Check if map dvd is correct"
but when i check the version, it's V 05.02.02 ... do i have to do anything before upgrade to the new MAP? or just insert the dvd??
here's the old Navi Map DVD V 04.05.01
backed up my original dvd map (data ver 04.2) and it works ... now i just gonna use the copy and keep the original at home...
Europe nav DVD
The military is sending me to Germany for 3 years, and I would like to swap out my nav DVD with a European version. Does anyone know a good source (original or burned)?
Also, will a 2006 version (US or Europe) work in my 03 system?
Thanks.
just got my updated map .... i think ... Ver. 05.1
(862171-33045 ... 464210-0660) ... it's for 4th gen navi.
my navi is 7005 (2005 4runner limited) ...
