need coilover help
hoss55
Hey guys. Looking to swapping out stock front suspension with a set of coilovers. My setup now is stock with 2 in coil spacer 2wd. I've tried looking and can't find many threads to help. I'm looking to find the somewhat cheaper route. Is there a direct fit coilover that just bolts in and will make up the difference that I will be losing from removing the spacer? Any input on prices and where I can find some( since there is soo many to choose from).
Coilovers like these come ready to bolt up ToyTec Coil Overs (95.5-04 Taco & 96-02 4RUN) - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
Otherwise you will need to disassemble your shock/spring combo to get the top plate out which will be used on your new springs and shocks.
2001ATL
