Need help: 04' headlight assem replacement
bossk4hire
Hi there ya'll.
I've got a 04 4runner and over the weekend had a chunk of tire get kicked-up by a car in-front of me and it took out the driver's side headlight lens. I've been trying to findout how to replace it. Thanks!!
Pictures or videos would be great!
I did find that I can't just buy the lens... have to get the whole thing... toyota wanted $224 for it.... gonna try a junk yard.
You can get a TYC unit on ebay for around $45-60 per side. Brand new.
And you have to remove the front bumper to get to all of the headlight assy bolts.
I just replaced mine. You just have to remove the radiator seal to get at one of the top
bolts. There is another bolt that is a bit tough but if you remove a couple of bolts from the fender liner, you can reach up there without much difficulty.
I'm on the road so I don't have access to any photos.
Thanks for the ideas and info.... the toyota folks did not give me the part # so im trying to find that so I can get one off of ebay but i want to make sure it's the right one. Thank you again!!!
Here are the part numbers:
Old Headlamp Assembly RH - 8113035420
Old Headlamp Assembly LH -8117035400
You might want to check out this thread if you are considering upgrading to the more modern headlights.
http://www.toyota-4runner.org/4th-gen-t4rs/115089-06-projector-headlight-upgrade.html
fixing to swap out my headlights to projector predator type...so will be removing my oem lights...am wondering if there is a writeup to removing the headlights.
someone just said u gotta remove th e front bumper...another said the radiator seal.....
Take a look at the diagram. There are three bolts. One is covered by the radiator seal (just plastic dressing).
help
So is it easier to remove the front bumper or the inner fender covers and lower grill trim on top of the bumper? I'm having trouble removing the lower grill trim . I'm down to using a sledge hammer or pulling the entire front bumper cover.
No need to remove the front bumper. You can have that headlight off in 10 minutes if you take a couple bolts out of the fender liner in the wheel well. You can actually see the bolt with a flashlight when you hold the fender liner back, and you should have enough room to get a socket wrench in there. The 4th bolt is a pain and will probably take a while if you've never done it before, but it can be done and removing the front bumper is a waste of time.
X2. I've taken my headlights off many times and NEVER took the bumper off. FYI: You don't have to reinstall that pesky bolt under the inner fender cover. I have retros and would have noticed the light moving on bumps.
