Need help installing Stealthbox and amp
Afro2cool
I have searched through many threads and I have yet to find what I am looking for. I would like to know if anyone can either give me detailed instructions to install an JL 250/1 amp and stealthbox into the factory JBL 10 speaker system w/ 6 disk changer or point me in the right direction or another thread. I would really appreciate the help.
If you are not familiar with wiring things like that, i would really pay a professional installer to do it. Getting into the premium sound systems is usually a very daunting task for even pro installers. There are usually more adapters and converteres that you will need to get, and youll need to get a wiring diagram etc etc.
If you think you can handle it yourself..
I would look around and google amp install on toyota JBL system...
Good Luck on the install...
-Nick
Wiring up an aftermarket sub to a factory stereo is not an easy task if you don't know what you are doing, and the sub is not going to sound as good as it would running off an aftermarket head unit that is compatible with a sub. I also know that the JBL system is a very strange setup concerning its wiring, amp, and compatability with other things. Point being I don't know if it will even work with the stealthbox. Hope someone else knows if it actually will or not.
I have read about the difficulty adding aftermarket products to the JBL system. I recently read about a product from JL audio called the Cleansweep CL441DSP. Here is the info from the JL site explaining what the product does:
What exactly does CleanSweep
I dont know if that would work or not...it says it converts an Analog signal to Digital, but I am pretty sure the JBL system is already a digital system....my main conern is that I have heard that the wiring is strang with the JBL system, people have said that you can't use an aftermarket HU with the JBL wiring, which really makes no sense to me, but that is partially why I say it might not work.
