Need help!! Lift question! Thanks!
Liana2015
OK, SO I HAVE A 2015 SR5.. I WANT TO DO AT LEAST A 3 IN LIFT.
Toyota 4Runner SST Lift Kit - 2003-2016
WILL THIS KIT ^ PROVIDE A THREE INCH LIFT AND BE LEVEL?
ALSO, WILL A THREE INCH LIFT BE NOTICABLE?
ANY OTHER RECC FOR LIFT IN THE 300-400 DOLLAR RANGE WOULD BE GREATLY APPRECIATE IT! THANKS IN ADVANCE
ANY PICS OF WHAT YOU HAVE WOULD BE AWESOME
IT WILL BE FOR COSMETICS. THE MOST OFF ROADING I WILL BE DOING IS GOING ON THE BEACH
Yes a 3 inch lift will be quite noticeable. Your ride quality might suffer though with the use of spacers. I personally haven't had them on a 4runner but from experience on other cars they can made the ride harsher. Just wanted to prepare you. Good luck with your lift.
The kit says its a 3"/2" lift which is the commonly accepted recipe for level for a 5th gen. There are cheaper spacer kits out there but they don't include the diff drop that yours does. Plenty of pictures on the Lift thread.
I went with a 2.5"/2" toytec spacer kit for the same exact reasons you stated. I wanted to keep a little rake in mine I case I have to haul a little trailer or future settling issues. It was well worth the lift. Tomorrow morning im getting 33" ko2's put on.
Below you will see before and after with stock sized nitro terra grapplers.
If you actually plan to wheel your truck, don't bother with spacers. save up a little longer and get a proper suspension lift with longer shocks and taller springs.
all spacers do is increase the preload on your springs without the addition of extra suspension travel. If you then decide to go out wheeling, you run the risk of over-extending the stock shocks and doing irreparable damage
Bilstein 5100's can be had for about $100 per corner, and will give you the height you want and proper suspension travel to go out and have fun
BIL-ADJSSS_zps83da2c35.jpg~original
matisgugle
