Need help with my airflow sensor
Gabriel33
I had a bad mass airflow sensor on my 88 4cly runner and I bought one off an 87 and now it my runner stays on and running but when I press the gas it seems to want to die
Has the AFM on the 87 been opened up? How does the contacts look like on the plug? How's the gasket between the AFM and the housing that the AFM mounts to? Double check that the charge pipe on the AFM is tight and there isn't any air leaking.
Look for the small things first. If all else fails then you can download the FSM in the sticky and troubleshoot your AFM. There are steps in the FSM to verify resistance for each pin to make sure the AFM is within specs.
increasedc
