NEED HELP with Tires and Spacer Lift questions
escalade25
RIMS
I have a 2005 SR5 4Runner and I just bought a new set of tires and I'm currently looking at replacing the rims with these Will these fit the new tires I just bought?: 16x7 American Racing 767 Black Wheel/Rim(s) 6x139.7 6-139.7 6x5.5 16-7 | eBay
SPACER LIFT: I do not know much about spacer lift or lift in general and I'm looking for that 3'' spacer lift. If I purchased these would these be all that I needed to lift the car up?: LIFT KIT BILLET B FRONT 3" REAR 2" 4-RUNNER 03-11 4WD W/ DIFF DROP | eBay
RIMS
For your lift question, read the suspension FAQ thread at the top of the 4th gen section. It should answer your questions and give you some info on the different types of lifts and the pro's/con's of each.
I personally would look at either the Daystar 2.5/1.5 or Toytec 3/2 (if you want the full 3" lift). Both have a great reputation. Those ebay spacer kits work I'm sure, but there's quality/name brand stuff out there for similar money. Also, general consensus is that the diff drop isn't required as it does very little to reduce the CV angles.
