ok so u just did some more investigating. the charge light is on. the volt meter docent work, water temp, oil pressure, and tach all stopped working at the same time. I just looked to see if the lights still work on it when you turn you lights on. they do, but the high beam indicator docent work now. when you turn the key to acc, the only warning light that works is the charging light. The only thing i have done to it in weeks is i ramed a pipe through that cat! it was bad anyway! i don't have to worrie about vehicle inspections.
