Seymore Butts
Does anyone have these part numbers? Just the rubber hoses from the hard lines to the radiator.
Just buy Gates 3/8” trans hose from auto parts store. If you get lucky, you can find Gates hose on ebay in bulk.
This is what I did with my ATF cooler install. My power steering and ATF cooler hard lines were rusted out and leaking, so I figured it was a good time to add an ATF cooler and just replace the rusted lines with ATF rubber lines. At the same time I bypassed the radiator cooler and just went straight from the transmission to the ATF cooler.
And I used 3/8" lines from a parts store, the rubber lines were rated for power steering or ATF.
I thought in cold climates it was best to run additional trans coolers in series after the radiator cooler to help the ATF get up to temp more quickly, and remain in the range of operating temps by exchanging some heat from the coolant/rest of the radiator?
Inlet hose - 32941-60280Does anyone have these part numbers? Just the rubber hoses from the hard lines to the radiator.
