need some lift advice
Davemon
Member
Well, the time is fast approaching (tax return time, that is), and I'm in the final stages of laying out all my options for lifts. And I have a few questions I hope the knowledgeable members of this forum can answer for me. First and foremost, I'll tell you a bit about my needs. I don't plan on wheeling my rig too seriously. The wife and kids don't like it too much, and I don't get out by myself that often. What I'm really looking for is about 2-2.5" of lift (so I can fit 285s under there), and improvement in the ride quality. I'm sick to death of the body roll, and "boaty"
feeling, especially in the turns. Nose dive is bad too, but doesn't seem to bug me as much. So, my question is this: will just an upgrade in tires (Cooper AT/3 in 285), and bilstein shocks (basically a levelling kit) give me the improvement I'm looking for? Or is it not going to give me enough of a difference without going to different front springs? If this is the case, I'll just cough up the cash for coilovers. But I'm on a tight budget, and willing to give up some offroad prowess to get the extras (like rims) that I wouldn't be able to afford with the pricier coilover setup. Any opinions on this matter would be GREATLY appreciated. I'm getting serious buyers indecision as the time gets closer.
personally I would use the money to get an accountant that can show you how to stop letting the IRS borrow money from you interest free....
but if not I would look into the TOYTEC ultimate lift
If your on a tight budget, Then I would definitely suggest the Bilstein 5100s front and rear, with either a coil spacer or new coils to lift the rear a bit. The bilsteins will provide up to 2.5" of lift, which will allow you to clear a 285. They have better valving than your stock shocks, and just the dynamics of lifting the front end will help get rid of the body roll in the front.
Bilsteins are great, but they are only half the equation. Springs are just as important to achieve the goals you have laid out. Stay away from coilovers, as they're overkill for your needs. Get a stock weight spring for the front axle (stiffer, but equal load carrying capacity), spacers for the rear (1-2.5" depending if you want to level, or maintain factory rake), and bilstein 5100's for all four corners. you'll notice a world of difference, and it's easy to swap out the rear springs later if you decide to upgrade. The work itself is pretty easy if you're comfortable turning wrenches.
LOL, thanks for the input. I'll be glad to discuss it with my current accountant (read: wife) but I don't think she'll listen to me this time either. And Toytec is the frontrunner, but I'd have to give up the new wheels (for now) to afford it.
Yep...that ^^^^ (on both counts).
I went through the very same analysis and ended up with the TT Ultimate and Cooper AT/3 285's on FN BFD 18" wheels.
All good...very good (I do NOT miss XREAS at all - not an issue for you I know).
Good luck.
