Need some pricing help
Monty87ls
Member
So I guess I might be selling my 4runner. Not real happy about it but the opportunity came up for me to get a very low mileage 08 Prius and I took it.. Yes I said Prius. The Mpgs are killing me and I'm just not sure I wanna watch it sit there and rot away.
Ive been trying to look around and see what's out there price wise but they are al over the place! dealers and private sellers. I even went and looked at a few locally and they were junk and one was obviously lying about the mileage and ran like crap. All wanted very high prices for miles ranging from 150k(supposedly) to 250k. The frames are junk and needed all kinds of work.
Mine is an 04 Sport 4WD in Silver. Mechanically I've taken very good care of it and fixed everything that needed fixing with top teir parts (OEM,Moog,Bilstein, ETC) All fluids changed within the past year, Transmission was done 4x times over at the time.
Currently it could use some brakes, I did purchased all brand new calipers, pads rotors, backing plates and SS brake hoses for a 5th ben upgrade but haven't installed yet. I started painting them black and then the Prius came into play so I put my time into that. Now its cold!
The exterior is where things get a bit hairy, the plastic was worn which I see is common and the plan was to strip and paint it next spring, thanks to someone flying around a corner and coming into my lane I swung to the side a bit and tapped a guard rail. No damage to any metal but the plastic along the whole side got messed up a bit. Seems very minor and I'm fairly certain with some light sanding and repaint it will not be noticeable.
Frame has had some repairs done to the front but the rest looks decent, frame treatment with paint and transmission fluid was also on the list but same deal because of the Prius I stopped and focused on that, given it was sitting for a year it also needed some attention.
Really mixed on selling it but right now trying to figure out where it might be priced given this market and the shape its in. I can post some pics if that helps but if anyone might be interested or has any idea where the price might be around i would appreciate it. Thank you!
Truck Is located in Dutchess County NY
With frame repair, cosmetic stuff on the exterior and brakes needing to be done and I’m guessing maybe 180 k for mileage, I think youre probably looking at around 6500 - maybe higher or lower depending on the local market and how savvy or “motivated” the buyer is, but that’s what I’d say is reasonable
Oh! forgot to put the mileage smh around 111,000. The brakes I can do, just need to decide if I want to use the stuff I have already or just do pads and rotors with existing calipers which function fine I was just gonna do it all over and then maybe sell the other stuff on here, that is if anyone would buy it.
I have the original wheels with decent tires but currently has 5th gen wheels and Cooper Discovery tires with less than 1,000 mile on them.
Thanks for the info. Maybe ill strip the plastic off and paint it in my garage make it look nice again before I sell it not sure.
its a shame about the frames on these and that I had to fix it or that anyone has to deal with it! be nice if could buy a car and have it not rot out from underneath them. Luckily mine wasn't so bad and it was just the rad support, I've seen some a lot worse on here.
Yea I think if you do the brakes, make a good effort at painting then you may be able to look at 8-8500 starting for an 04 with 111k with good interest. Could start a little higher and see if you get bites
I wouldnt waste time fixing and painting. You arent going to get much out of it for the effort and time spent. Id just put the stuff in the back and sell as is.
Sent from my Pixel 3 using Tapatalk
erinobr2000
