Need some switch Info (Not Lights)
El Jefe
Way back on my 2nd post I had some interaction with "Warpwr" on how to wire up a fog light switch. I noticed in his post that his Taco had what appears to be a double pole double throw power switch.... Any chance someone knows a part number? Thanks Andy
Hey Andy. I thought I remembered seeing that switch in another Toyota as well as the Taco, but can't remember which one. Anyway, not sure if you know of 1sttoyotaparts.com (https://www.1sttoyotaparts.com/oempartscat.html) or Conicelli Parts (Conicelli Parts Center), but I found the switch under the Tacoma, but it's apparently mislabeled and no info for it came up. (Conicelli Parts Center)
I would just give them a call and they should be able to look it up for you. It'll probably run you $45 - $50 I'm guessing.
Wow, after looking at the parts breakdown again, it's WAY off. For example, in the pic, #3 is for the fog light switch. But in the picture, it's pointing to the inst cluster trim piece.
BillM777
