New 2005 SR5 4X4
4RunnerOU
Hi everyone,
Finally I bought my 2005 SR5 4x4. I really appreciate all of you in this forum who had given your valuable comments about this truck. So far, I have 150 miles on it already. It feels great on the road.
Here are something I noticed when I am driving on the road since I owned it.
1. On top of the front driver window, I heard rattling noise. I found that there was a screw on the roof cross bar that was loose. I have tightened it down. hope that the problem is solved. I will need to get up on the highway again to make sure.
2. The steering alignment is off. The service department will take care of that for me this Saturday.
3. I smelt something from the engine the first day I brought the truck back home. I was not sure it is the so called "sulphur" smell. To me, it is more like a electric fuse burning smell. It is gone now after 50 miles.
One thing I want to ask the experts here. With regards to changing from H2 to H4. Are you supposed to "feel" anything indicating the 4 wheels has been engaged? I feel nothing except I see the light is on.
Overall, I like my 4Runner.
Congrats on the new ride!
Nope, I don't feel anything when switching. I do notice though that the vehicle is in 4WD. The way it drives becomes difference, maybe its being a little more sluggish since all the wheels have power sent to them.
that new car smell
"3. I smelt something from the engine the first day I brought the truck back home. I was not sure it is the so called "sulphur" smell. To me, it is more like a electric fuse burning smell. It is gone now after 50 miles."
I smelled something similar to that too in mine. Turned out to be the new wiring and connectors had never been tested with a load. Once everything was loaded I got that smell, but it quickly went away and never returned (2k miles now). This is normal with brand new electronics.
"One thing I want to ask the experts here. With regards to changing from H2 to H4. Are you supposed to "feel" anything indicating the 4 wheels has been engaged? I feel nothing except I see the light is on."
No, you will not feel a thing. I was beginning to wonder whether 4WD was actually engaged until I hit a sand patch in the road. The I knew it engaged.
toyota offers an one time alignment check under 12k miles.
use it and abuse it! (but remember they take a full day to do :( )
Here is a picture of my new 4Runner. As you can see, I have taken out the dealership nameplate out from the front bumper. It looks ugly. This weekend, I am going to put my favorite college logo plate on it.
Looks good. By the way, the steering on my truck does seem to feel a bit "heavier" when in 4wd rather than 2wd.
Your truck looks great!
Regarding that rattling above the drivers door. I had the same thing. Heard it with wind gusts and bumps. I thought it was the front roof rack cover but it turned out to be a screw on the back cross bar. I'm sure that was your problem as well.
I don't know where 4RunnerOU lives, but in New York, all manufacturers are required by law to provide a free alignment within the first 12 months or 12K miles for any make or model.
Other states may be the same....
Hitman,
I can post a picture of the wheel when I get home. I did not do anything special, the wheels are standard.
I live in Oklahoma. Thanks for the information on the free alignment. When I noticed the alignment is off, I made a phone call to the service department manager right away. It was only 4 days from the day I bought. That's good enough to show them that the problem exist from the very beginning.
Another strange thing happened to me yesterday. It was around 28F. For people live in Oklahoma, it is COLD!
So, I adjusted the temperature up from 68 to 75 with the fan speed set at "HI". I noticed that the fan speed started to go slow when I set to 74 or 75. When I turn the setting back down to 66 or 65, the fan speed started to increase. Weird? Any experts here experience this? Why?
"Another strange thing happened to me yesterday. It was around 28F. For people live in Oklahoma, it is COLD!
So, I adjusted the temperature up from 68 to 75 with the fan speed set at "HI". I noticed that the fan speed started to go slow when I set to 74 or 75. When I turn the setting back down to 66 or 65, the fan speed started to increase. Weird? Any experts here experience this? Why?"
Well, I don't think I'd qualify myself as an expert :), but if you had just gotten in the car, you can't turn the heater up that high and have it blow hot air out at you. In fact, I've experienced the same thing you have - the heater knows it's not warm enough, so it won't let you just blow cold air at the "high" setting. When you turn the temp setting back down to 65 or 66, it might be warm enough to blow that temp air, so it lets the fan speed back up. Once the car is fully warmed up, however, you should be able to blow 75 or 80 degree air out at the "high" setting. If not, then something is wrong. Other than that, sounds like it's operating perfectly normal to me.
P.S. You may be able to disable this "temp sensing" feature by turning off the "Auto" option, but can't remember for sure at the moment.
Hope this helps...
-Alex
4RunnerOU said:
Hitman,
I believe Hitman is mentioning that not many 4Runners go out with 16" rims. The SE comes with a unique set of 17" and the Limited also comes with 17". The SR5 comes standard with the 16" rims you have on your truck, but most people opt for the 17" wheels.
16" wheels are great if you're going offroading. It means you'll have more rubber between your rim and the road, 16" tires are cheaper as well as you'll have a greater selection.
Congrats again!
In So. CA, it's nearly impossible to find an SR5 with the 17" wheels, all of them come with 16's. I've only seen ONE SR5 (other than mine) that had the 17" wheels, it also had the factory spoiler too (another rare option for SR5's over here). I'm guessing they bought it somewhere else and brought it over here. Of course, mine came with the 16's and I put on the 17's after I bought it.
Wow its the polar opposite her in the Washington DC Metro area. I've never seen a T4R with 16" wheels except on here.
same here in northern california, never seen an sr5 with 16" wheels. they all look like mine!
