New BajaRack already showing signs of surface rust!
psiems
Hey there,
I decided to go with a roof rack earlier this summer and decided on Baja Rack primarily because I did not want to drill holes in my roof or attach an aftermarket rack to my factory rails.
Recently, I noticed rust showing up around some of the welds. I assume that the zinc primer and/or powder coat did not thoroughly cover these areas. I don't want to send it back because of the hassle it involves. I know that if I leave things the way they are it will only get worse. By the way, I live in Michigan and we use salt on our roads during the winter months. Any painters out there that may have some advice? I was thinking of trying to match the color using touch up paint. What should I do first to prep the surface?
Hey there,
I'm not a painter, but I would rough up the areas around the rust, spread a little POR-15 around and on the rust then use some touch up paint. While you're at it paint the underside of your car with the POR-15 to prevent future rust. I used it on the underside of my car.
If that rack was installed this past summer as you suggest then it hasn't even seen a winter (or salt) yet and I would be putting this question (and others) to Baja Racks for their solution. Having any rust show up on a new rack is unacceptable and I would suggest that the rack should be replaced. I would contact Baja and see what they are willing to do about it.
If you want to beat the crap out of it forever and not worry about it, go with the POR-15 and then paint over it. POR-15 is great stuff, done quite a few jobs with it, but it has no UV coating so it will fade if not painted over.
I have had mine on for about a year or so and always have camping gear loaded up on it. No surface rust anywhere. The POR-15 will definitely do the trick for you though.
