New Falken AT tire (A/T3W)
Thank you for the quick reply. Is there any tire that will fit without modding the truck at all? Thank you!
If you kept the trail/TRDOR wheels, the tires would most likely never rub (mine didn't when I had it set up that way with the Wildpeaks).
Keep in mind, even the TRD Pros get this exact modification (fender liner pushed forward/bumper trim) done at the port when they get off the ship. So doing it yourself isn't really any more intrusive than what "the factory" does.
Thank you my man. Trimming it is then.
There is still a slight chance I might not need to trim correct?
I put the TRD Pro wheels and these tires on with stock size. Only slight rubbing when in reverse for me with the wheel turned all the way to the right.
I've read every forum over the last week regarding this issue. Can someone please tell me if I am right or wrong.
I own a 2018 TRD ORP. I recently bought the TRD rims, but haven't bought a tire yet.
From what I am reading with the offset no matter what tire I buy at 265/70/17 or 275/70/17 there is a chance it will rub? I have seen a different outcome on basically every forum.
I do not want to lift and I'm looking for an AT tire. Toyo, Falken, Cooper.
Is there any tire that can guarantee it will not rub as I am looking to purchase this week. Any advice/suggestions are appreciated. Thanks!
If you a search for fender mod a bunch show up. Here's one of them that might help.
Fender liner mod
This is 285/70/17 with TRD Pro rims. All I did was do the fender liner mod. No lift. More pics on Instagram @4lzunner (scroll all the way down)
Sent from my SM-N950U using Tapatalk
I have the same rims and size, ran with stock suspension for a week or 2 with zero rubbing. Not sure why as I would have thought all runners are the same at port and unless they fell off the truck shouldn't align any different
Why isn’t this more known? People act like 285’s require big lifts.
The fact of the matter is that EVERY rig is different. Period. That’s why there are so many conflicting reports in this. Some don’t have an issue. Some do. It’s just that simple. You won’t know until you try.
This is an insane value. I am annoyed that it starts at less than the advertised depth and that the first 2/32nds go away in 4,000 miles or less, but for the rest it is an exceptional tire regardless of price. Throw in a cost this low and it is hard to complain...
Ended up going with the Cooper Adventure AT 265/70/17. Full crank both ways I have no rubbing. Very happy with the choice and it worked out.
Ended up ordering, was going to wait until late fall, but could not pass up with that price. Doesn't hurt getting 5% back using the Amazon card too.
Who are you having mount and balance when buying from Amazon or Walmart?
Local shops or national chain? I keep telling myself that I'm going to wait a little longer to replace the original tires, but I know that isn't going to happen.
Luckily I have a friend who is installing them along with a 1" front spacer. However, when going through ordering on Amazon it gave me about a dozen national shops/local chains (mostly Sears). It also gave me the option for at-home installation through a company I can't recall the name of.
Tempted to get my spare changed over at that price.
From what, the stock one? Absolutely. The Wildpeaks are strong but not perfect. You may well need that spare. I have needed it twice in the desert.
I would first ask the local Discount Tire if they would match Walmart. If not, buy from either Amazon and Walmart and have them mounted by Discount Tire. That should give you free lifetime balancing and rotations. At least this is the case here. I don't care for the rotations but I cannot balance my tires myself.
When I bought a month ago discount matched Amazon. Go on the web site and ask. They sent me a code good at any discount tire good for 30 days
Yep my spare is the stock one. In my mind the added benefit of sticking to the stock tire size is being able to use the stock spare.
lindwlson982
