Dellethekidd
Thank you for the quick reply. Is there any tire that will fit without modding the truck at all? Thank you!
Thank you my man. Trimming it is then.
There is still a slight chance I might not need to trim correct?
I've read every forum over the last week regarding this issue. Can someone please tell me if I am right or wrong.
I own a 2018 TRD ORP. I recently bought the TRD rims, but haven't bought a tire yet.
From what I am reading with the offset no matter what tire I buy at 265/70/17 or 275/70/17 there is a chance it will rub? I have seen a different outcome on basically every forum.
I do not want to lift and I'm looking for an AT tire. Toyo, Falken, Cooper.
Is there any tire that can guarantee it will not rub as I am looking to purchase this week. Any advice/suggestions are appreciated. Thanks!
This is 285/70/17 with TRD Pro rims. All I did was do the fender liner mod. No lift. More pics on Instagram @4lzunner (scroll all the way down)Thank you my man. Trimming it is then.
I have the same rims and size, ran with stock suspension for a week or 2 with zero rubbing. Not sure why as I would have thought all runners are the same at port and unless they fell off the truck shouldn't align any differentI put the TRD Pro wheels and these tires on with stock size. Only slight rubbing when in reverse for me with the wheel turned all the way to the right.
Why isn’t this more known? People act like 285’s require big lifts.
Just an FYI these dropped to $126 on Amazon for P rated OEM size.
Who are you having mount and balance when buying from Amazon or Walmart?
Local shops or national chain? I keep telling myself that I'm going to wait a little longer to replace the original tires, but I know that isn't going to happen.
Tempted to get my spare changed over at that price.
From what, the stock one? Absolutely. The Wildpeaks are strong but not perfect. You may well need that spare. I have needed it twice in the desert.
I would first ask the local Discount Tire if they would match Walmart. If not, buy from either Amazon and Walmart and have them mounted by Discount Tire. That should give you free lifetime balancing and rotations. At least this is the case here. I don't care for the rotations but I cannot balance my tires myself.
