New fine-grained VSC OFF Mod for V6 1GR
Is this thread dead? I really need some help. If it helps at all my 4wd also stopped working and I think the actuator might be jammed from possibly landing on a rock in my backyard. That or wiring.
This is not related to this thread and should be posted in the general 4th Gen Forum for advice.
Sounds like if you landed on something hard enough you could have damaged the actuator in the t-case. Post up like I said in the other forum. Try to get underneath and inspect, take some photos, etc. for others to visually inspect and advise on.
Well I was mainly saying that I have posted three times and no one has tried to help. I thought that maybe the 4wd thing was related to my wiring and that it could help troubleshoot it but I couldn't narrow it down because I did hit a rock as well on something.
Turns out it was the wiring. The 4wd ecu has a red/blue wire and a blue/red wire and I chose the wrong one. This fixed the 4wd issue but my mod still isn't quite working. I think it's my wiring to the center diff lock switch.
Fixed everything I found wrong and still doesn't work.
I double checked my diff lock wires, my vsc off switch wires, and all other connections. When the 4wd ecu wire is attached, the 4wd actuator goes limp and wont let me shift to 4wd or anything. When I attach it to the other blue/red wire on the 4wd everything works fine but the vsc off switch just lights up the abs light and doesn't disable traction control.
Any help?
Help
I discovered that the 4wd actuator was actually not working due to the wire going to the 4wd ecu from the vsc off device. When I touch it to the blue/red wire the 4wd works fine but the vsc off switch just lights up the abs light on the dash. This same thing happens when no wires are tapped into the 4wd ecu. When I attach the wire to the red/blue wire on the 4wd the 4wd actuator stops working and makes everything blink. It displays multiple wrong lights on the dash includiung center diff lock vsc off and 4wd even when none of these things are true. (I tested it by seeing if I was in 4wd and cranking the wheel to full luck. Also vsc wasn't off as far as I could tell.
To clarify, you still don't have everything working correctly with the VSC device wired per the instructions (or otherwise)? Does it look like the latest version is malfunctioning? I have the revised device sitting on the shelf waiting to be installed. Maybe I should hold off until there is confirmation it is working correctly.
I double checked all my wiring and it seems to be all good. I messed up a few wires originaly but nothing shorted and when I disconnect the wire to the 4wd ecu everything works as usual but the vsc off switch just lights up the abs light on the dash when pressed and depressed. What could be wrong? Whej the 4wd ecu wire is taped into the red/blue striped wire the 4wd actuator flashes on the dash and I can't do anything. Shift drive modes center diff lock nothing.
Thanks.
Selling my unit
Hey guys. After many attempts I was unable to successfully install my unit. I have decided to sell it. It is in good condition except I took off the blue tape covering. I am located in California and will pay shipping. Shoot me an offer.
Thanks for the update Rob! Hope you enjoy it.
Please check Yellow and Orange wires orientation
As a reminder. Will refund 10USD for every broken unit sent back - Thanks!
Finally got around to doing this and switching wire orientation, correct lights illuminate now (VSC off)
Now, when I go to use the unit I can still feel the a-trac kicking on even when using the mod. Is that how it supposed to operate?
Are you still selling this?
Yes,i too would like one of these,@kliv,dm me if you are still making these,ive been needing one for quite some time
Sent from my SM-G965U using Tapatalk
Not sure if Kliv is still selling these, but if anyone is interested, I have had one for about a year now that I still haven’t installed due to other priorities, and would consider selling. I also have a brand new factory Toyota FJ switch along with the connector plug and the factory pigtail wires. Complete kit basically. Pm me if interested.
still have this available ?
Runvod
