[MENTION=131466]Superjet[/MENTION],
Ok folks I had my Kenwood DNX693S installed last night and I'm still messing around with it, but here are two things I'm seeing right now:
1) The Maestro RR unit seems to not provide for the up/down (arrows) functions on the steering wheel, so that I can flip through my preset stations for HD radio, Satellite radio etc. I can use the left/right (arrows), but all that does is advance the station by one, for example if listening to FM radio and I'm on preset 1 (97.9), it just moves the station to 98.0 or 97.6, it doesnt move to preset #2. Same with XM, if I'm on Lithium (#34) and use the arrows it goes to 34 or 36, not the next preset.
To get the Kenwood to jump to the next/previous preset station, you have to set the "seek" method to "seek 2". "Seek 1" means to progress 1 station at a time (I think we used to call this "scan" back in the day). "Seek 2" means to progress 1 preset at a time (I think we used to call this "seek" back in the day). In the Kenwood world, the "seek" method on my head unit is at the top of the screen (for HD Radio and XM Radio)... it's a little rectangle button that says "Seek x". Once you get the seek method set, the steering wheel buttons you have programmed will advance the way you want it to. I would love it if I could program the left/right steering wheel buttons to jump forward/back one preset at a time (old timey seek) AND program the up/down steering wheel buttons to jump forward/back one station at a time (old timey scan). But alas, the Kenwood doesn't work that way.
2) The USB on the center stack seems to not be usable for the apple carplay. When I plugged the iphone 6S+ into it, I got a "ipod not recognized" message. Went back to the install shop and they had installed the Kenwood Apple iphone/ipod cable USB in the glovebox. Thats not gonna fly as I need it closer. Will try and see if I can re route under the dash somewhere else.
I do have the axxess AX-TOY-USB2 withthe brown plug end, but dont think thats gonna work.
Nope. The AX-TOY-USB2 won't work (as noted in one of my earlier posts). You need the AX-TOY-USB. The Maestro wiring harness kit (TO2) also comes with the adapter you need. Look at this picture on the Crutchfield page (https://www.crutchfield.com/p_794HRRTO2/iDatalink-HRN-RR-TO2-Factory-Integration-Adapter.html). On the left-hand side of the photo is a gray plug block thing. You can't really tell what the other end of that cable looks like because all of that goes into a bundle, but you can see the black USB male end right next to the gray plug block thing. That's what you need to connect the Kenwood ipod/iphone USB plug to the center stack USB plug. The black USB male plug end goes in the Kenwood female USB plug (the one you said they were going to put in your glove box). The gray part connects to the center stack USB plug.
BEFORE you go on a rampage trying to find out where that gray plug goes: It does NOT plug directly into the back of the USB plug in the center stack. There is a factory cable that is plugged into the back of the center stack USB plug. Follow that cable up into the dash a few inches... toward the head unit. On the end of that cable is a block pluggy thingy that you will plug the gray end of your adapter from the TO2 kit. BEWARE: This is how it was done on my 2016. I initially couldn't figure out where that gray plug went. A google search found lots of people having this problem and their solution was to remove the glove box and dig around for something behind it. I did this and the doo-dad that was supposed to be back there, wasn't back there. Apparently, that's relevant for older models. I wasted 2 or 3 hours chasing that rabbit down the wrong hole.
So far though, happy with how it came out. My radio does not have the advanced functions for the cars settings (unless I havent found them yet) all I see is gauges and tire pressure. Nothing to change settings for wiper interval etc.
I think your radio is a step-up from mine, so I'm pretty sure you have those advanced settings. I initially couldn't find them. I think it's available somewhere weird... like OEM settings or something. I'll have to look at my radio later... but you might be able to find them they way I did... keep pushing buttons for a few hours until you happen across the right combination.
Body shop did an excellent job painting the scosche faceplate as well
**EDIT** - [MENTION=147757]GearJunkie88[/MENTION],
Just saw your above post and I'm confused. I got some parts back with my install and didnt see the other adapter? perhpas they kept it?
That adapter is definitely in the TO2 kit. If they didn't use it, they should have given it back to you.
Either way I'm confused as when I look up that adapter, the TOYUSB, I'm assuming the gray end plugs into the Kenwood HU, and then where does the USB plug fit? Will taht then plug into the center stack USB on the backside?
No. Black male USB end goes in the Kenwood female USB "extension" cable. Gray end goes to the cable that connects to the center stack USB (again -- it does not plug directly into the back of the center stack USB plug assembly... you'll need to track down the end of that cable... it's not that far from the center stack USB plug assembly, but from what I recall, it was tucked up under something).
