new owner
my dime
Hello everyone
I have just recently purchased a used 2007 sport edition and I love it!
im kinda confused on a few things though and was hoping for some help.
#1
power outlet 12v by gear shift but is there only one up front?
#2 rear console hatch I assume is by my right arm behind gear shifter and I do see the aux.adapter down at bottom but mine does not have 115v or a.v adapter.why is that?
#3 I do see air lines going to shocks but thete is not a switch in the center console to operate them.is that correct?
sure could use the help to know.
#4 do the head lights come on automatically based upon outside light? My orange marker lights do.
#5 fuel range indicator will not reset after refueling at 3/4 of a tank.if I understand correctly this is normal because of how soon I refilled? If not is there a way I cam manually reset besides disconnecting the battery?
Really appreciate the help and information guys.thank you
Welcome, I will answer what I know below.
Hello everyone
#1
YES
THE REAR WINDOW SWITCH SHOULD BE ON THE DASH LEFT OF RADIO, 115V WAS OPTION AND SWITCH WOULD BE LOCATED LEFT OF STEERING WHEEL
NOT AIR LINES, THEY ARE HYDRAULIC LINES FOR THE XREAS SUSPENSION
NO UNLESS YOU UPGRADE THE TURN SIGNAL STALK AND IT HAS A ADDITIONAL POSITION MARKED AUTO
NOT SURE ON THIS
Check out this link, some great info:
http://www.toyota-4runner.org/4th-gen-t4rs/136498-pre-purchase-info-modifications-write-ups-quick-links-faqs.html
The orange marker lights coming on up front when you start the rig is the "Daytime" running light. Marker lights go out when headlights are fully on.
To run the vehicle without the marker lights coming on, like my wife used to do, working lot security at night, but needed to run the A/C, push down your parking brake before starting the rig, then they are off.
Hello everyone
#1
Regarding #3: Those are NOT "AIR LINES". Those are actually hydraulic lines for the XREAS system, which in a nutshell, connects all 4 shocks to each other, hydraulically, to improve cornering. When the vehicle leans away from the turn, the system redirects the hydraulic pressure to the shocks that are compressing, therefore reducing turn "lean". The SPORT EDITION came with this feature as standard.
Regarding #5: I am assuming that by "fuel range indicator", you are referring to lcd display on the HVAC control/info panel, correct? If so, I have never had that problem. Whilst the "fuel range" feature is notoriously inaccurate, it should adjust the range after you fill up, regardless of how much fuel was in the tank preceding said fill up.
Talyn
