New power window switch....help
WANTSUM411
Sick of fighting the OLD Switches so I Bought new 5 Pole Switches .....now I need to know where to go with what wires & will Aftermarket Switches Work ?
Should the Switches have came with Instructions ???
Terminals on Switch are Labeled a b c d e ....& L ( Luminated Switches )
A is ctr , B is rt , C is on left ,D is top rt , E is bot left , L is bottom rt .
Thanks for any & all help !
I'll take a look at mine later, but I dont think it will work because of my bypass. I took the old switches out and cleaned them, but dropped it in the process and the parts went all over. Housing was brittle and cracked. I was able to test and see the problem was dirty contacts. But I gave up and ordered generic ones off amazon.
I also bought relays for them, but I couldn't decide on the proper way to wire it up and just ran straight power from the fuse box and ground to the chassis.
Really dont want to hold the button down once the window is down. May fix in the future, but the SAS is taking all my time.
Ok ...I have got the Pin Out for the Switch , it is a Reverse Polarity switch , that is what the 1985 tr4 are right ?
just need to know which 2 wires are - & which 2 are Motor .
Looking at the 95 FSM schematic, the switch terminals are numbered, not letters, and I don't see any of the color combinations I think I see in your pic. All should have a stripe and a main color of blue or red. It differs f/r and l/r.
The Switch is a Aftermarket Spal 5 Contact & I have the Pinout on it ....now . It shows 1 + , 2 - , 2 mtr .....I am looking for which wires are what on the door side , I know which one is 12vlt ...but not sure on the 2 - ... & 2 mtr.
Switch is for front Pas Door Window , 1985 SR5 4 Runner
Factory wires are Sld Green = Neg
Sld Blue =12 vlt
Green / Yellow =mtr
Red / Yellow =mtr
Red / Blue =Neg
I used a Spal # IB17400049 Window Switch $9.14 ea thru one of my Suppliers . Spal has the Pinout on their Website .
I will have to Fab a Lil Housing for the Switch but ...it WORKS ...now to move on & Replace my Back Window Switch Too !
Thanks for All the help !
