New Rotors & Pads On a 2008 SR5- Difficulty Level?
Just the fasteners (bolts, nuts, etc.) or other mating surfaces as well?
Yes in the bolts, nuts, etc., anywhere you have fasteners for the most part so they don't seize up/rust/corrode, but on all the parts that move, slide or rub together, pins, caliper to caliper bracket, etc, you need to add some type of brake parts lube, you don't need a lot just an even thin coat will do.
This is one such brake parts lube and pretty good stuff and stays where you put it for the most part.
https://www.amazon.com/Napa-7651346-Silicone-Lubricating-Compound/dp/B0054DWS1W
erinobr2000
