New Tires
boston_kevin
New Michelin's on the street... I wonder what the off-road version will look like. Rumor has it that these will be out next year... So much for those tire pressure warning systems.
They need to seal up the sidewalls because they look like shit. Those tires have been kicked around for a couple years. There must be some issues with them.
Koz
Koz
yea, nowhere to put armourall! :D
Koz
:iagree: couldn't have said it better.
U G L Y ...UGLY!!!
I thought these were going to be marketed as Spares? At least if its your spare, its weighs alot less and you should be able to store stuff in between the cracks and strap em in with masking tape:biggrin2:
Arent these tires showing the "run-flat" technology? It looks like the regular tire would be enclosed but incase you had a puncture , you could still drive it to a station or home untill you got it fixed
These tires are actually showing the technology to run without air entirely. Run-flat allows you to run without air for up to 50 miles (due to sidewall and rubber compound changes) - enough to get to a garage or get home.
I like the idea of having this as a spare, no need to have the stupid low-pressure sensor sending an alarm because the pressure is below 28 lbs...
Do everything you can to avoid "run flat" tires, they are nothing but an expensive PITA.
Koz
Jesse1
