New tool for me to try
greasefingers
I call this a nut buster! I just picked it up, so I cannot comment yet. I guess it will prevent rounding the corners off of stubborn nuts and bolts.
wrench2.jpg~original
Woo that rear drive sprocket is huge. Is it so torque-ie that the front end lifts? What is the width of those tires?:jaw drop:
Yes, very torquey but front end won't lift because it has a sprocket the same size on the other side of the front wheel.
It's a 2x2. Driveshaft through main frame tube to miter box on front fender (same as rear) that transmits power to front wheel.
The Goodyears are about 8" wide.
Bob
My dad gave me a complete craftsman tool set a few years ago. The tool pictured was part of the set.
I did not think much about it at the time, but I swear that I use that thing more than any other tool. It can get into tight spots and once you clamp it on, it never slips.
Wow I guess I'll try mine.
I received a set of these - two sizes for xmas about 3 years ago. I have never tried them because ...well....they just look gimmicky ?
Popeal wrenches ?
They don't look like they would be good for tight spots. You need more room around a bolt head then a conventional box end or socket right ?
I meant tight from the top of the bolt.
edcultural
