Newb update
LuvDLions
Newb update - pics added
Most importantly, we named her Luci!
Last weekend we took off the running boards and mudflaps, installed a junkyard radio (complete with cassette deck), replaced the dash lights, installed a new headlight assy and turn signal light, adjusted the loose throttle cable and kick down cable.
Today I got NGK platinum plugs and plug wire kit, cap, rotor, air filter, oil filter, oil, fuel filter, egr valve and a battery. The battery already was installed and it's amazing, it cranks and fires right up on the first try. No more cranking and cranking. It is only an occasional problem but the RPM's will drop to around 500 and bounce around there. I rev it and it picks right back up. Hopefully once I install all of these tune-up items, it will not run rough anymore.
Oh, I drove it to work this morning, 35 miles one way and there is a sizable oil leak out in the parking lot. I guess I will have to jack it up and see what that's all about too. Bonus - Found out the cruise control works! :laugh:
Wish me luck!
attempting pics
still need to reinstall the grill.
Holy Moley!!! Next time you find a deal like that, let me know! Me Likey!!
There is another one in town or was, that I talked the guy down to $1100. 1993, auto, 4wd, white.
The bad...
No cat
No tail pipe
Major Oil leaks
Interior is rough
I can see if it is still available and pass on the info if you want.
Justin have u run Gold Mtn. ? How tough is it compared with White Mtn., Lower Larga Flats, or DishPan Springs? I'm planning on doing Gold Mtn. next and I think I remember u saying u ran it before. I've run the other 3 already. Thanks
If that is your rig in the picture, you will be able to do it no problem. There's probably a little snow up there now though.
Would you like to get rid of your running boards, I looking for some
That's a possibility, I think the dog already started chewing on one the rubber end caps. My wife left them in the garage because it was too cold and there you go... PM me.
I have also seen about 5-6 4runners at the Ontario pick a part and from thurs-sun everything is 50% off.
Yes that's one of my rigs. I think ur right about the snow. And there's supposed to be more coming later this week. I'm thinking about the Cleghorn run instead since its easier than Gold Mtn. Now I just gotta check n see if I can find my chains. You gotta carry 'em with u...(frickn CHP). :driving:
