Newbie question....unplugging elocker
jfeg
I’ve got most everything disconnected to remove the rear axle. The larger plug for the locker was easy enough. But I can’t seem to get the smaller one unplugged. What’s holding it on?
It has a locking clip on it - I think you lift up.
Like the little one in the pic?
All of the connectors are simple. Just push and pull up. Might need to get a small pick under it while you push on the pin to unlock it.
yes they are normally simple, plug and play..push the clip
but crud and electrical bonding of pins and sockets over years can make a simple pull a struggle...make plastic brittle... where your hoping....please don't break
CRC makes electrical contact cleaner and one for plastic safe contact cleaner.
I have had luck spraying the latter into a stuck connection and it worked..but maybe it was just me constantly wiggling and shooting some kind of juice into it to help make things slide .
I play on back roads with lots of grime built up...but no rust :)...sometimes its just the grit and dirt
AndiGarage
