No rear window wiper, washer, defog- NOT FUSE
stanleyoutdoors
As title says, my rear window wiper, washer, and defog don't work, but it does not seem to be a blown fuse (unless it's labeled something really weird).
2006 Sport Edition, V6, RWD
Any thoughts?
Any thoughts?
This may sound goofy but did you make sure it's all the way rolled up? This happened to me once and it was rolled down just slightly so you couldn't even notice.
+1 on this. It drove me nutz to two weeks until I figure it out...:frusty::frusty::frusty:
Run window all the way down, then all the way up. May want to do this with drivers door window and moonroof also.
same here, also try to roll it up from the back and “help” it a little when it gets to the top. Check your wiper position too, my first gen was super finicky about the wiper position, had to manually move the wiper up and down to find the right spot with the key in the lift gate. Huge PITA
good luck, let us know what you found
TerryNap61
