homeyclaus
Couldn't a set of cheap (thin) jump cables fit under the rear seat, even they are folded down? Just a thought. Be safe.
There is also space under the hood for stuff like that. But mine are under the driver's seat, mainly to avoid having to dig though all the stuff in the back to jump someone (likely) or get jumped (not as likely).
I'm surprised that nobody mentioned dual battery setup yet. Not as cheap as having jump cables or booster accessible but it would completely eliminate dead battery problem.
Read some of the threads on dual battery setups on here. Great idea. When done wrong, it brings with it a whole host of other issues.
is this smart key only? I could have sworn my SR5 unlocks with the key... will have to go out at lunch and check it out
As said, your key in the back sends an electrical signal. It's not mechanically connected to the latch, and in fact, the latch is electric too.
hmmmm.... makes sense if that is the case... but doesnt make sense why it would be designed like that
As said: rear sliding window with a rear liftgate. Electric wiring is more reliable in all cases but this one.
