noob question about wiring turn signal
7iger4runner
currently using motorcycle led turn signal for my 4runner (front end)
I am planning to change to cube spot light as turn signal.
my question is: is it ok to run the wire straight to oem turn signal wire? or should I run the relay between spot light wire and oem turn signal wire?
have anyone done this before?
lmk, thanks
lmk, thanks
If it's LED, you'll likely need a resistor. LowRange Offroad sells some for their LED kits....but I'm not sure they are the right rating for your MC light.
LED Light Resistor Kit (2905)
2001ATL
