Noob Question…Off-Roading Essentials
Duct tape and zips ties for sure.
I have a lot of experience in off-roading in places where ppl don’t usually go. I’m in SoCal and building up my 4runner now with the plan to go do some testing up in bArstow area / Mojave’s area in December. Then a Baja run in feb or March. You can totally come a long. Get your self a vhf hand held radio.
Did you notice this post was more than a year old?
If this thread was 10 years old, I still find it useful.
A noob myself, that used the search button.
Sent from my SM-G955U using Tapatalk
Shackles and Straps are not as useful without a winch or a hi lift jack, even with trees. Specifically not useful in the desert.
- Check out MaxTrax or Tred Pro's for getting yourself out of mud/sand (can be used as shovels as well)
- Ham Radio and GPS are both highly recommended if you are in a pinch.
- Self starting jumper battery pack
- Always take extra food and water in case you get stranded
- First aid kit for sure
[MENTION=55815]Okki[/MENTION] has helped me quite a bit with recovery, maybe he can share his list with you :)
Anza Borrego is off roading paradise and there's all kinds of terrain and levels you can tackle.
I'm about 15 minutes from you and would be down to plan a trip out there. probably in late July/Early August. Also check out the Socal section on the forum.
IDK how old your kids are but I would not go out where with a kid younger than 3 or 4 ... Lot's of bouncing around
Good luck man!
id say this guy has got it down pat.
Do you guys a recommend an aftermarket recovery point such as one from ARB on a stock 4runner in case the time comes for a recovery from another vehicle?
Definitely recommend the ARB ones - they are really solid. I have a pair on mine and I've used them several times now when I've been stuck.
The front factory tow points are more than adequate for recovery. Read some of the technical aspects from [MENTION=106176]wfo9[/MENTION] and [MENTION=118321]Jetboy[/MENTION] in the thread below. I've recovered with them multilple times and once in deep mud with no issues. It's your money but with a d-shackle and recovery strap attached you should be able to use the factory points without issue.
Front Recovery Point Interest Thread
erinobr2000
