NoOneBetter
Member
For me, I won't be ordering CH4x4 switches in the future and will stick to AOB. Though, I'll use the CH4x4 one that I have. The material and feel of the button click is better with the AOB. Also, in case you didn't notice, I have my CH4x4 switch sticking out further than the rest of the switches because if you push the switch all the way into to mounting hole, the mounting frame around the switch slightly blocks the travel of the switch to the point where you can no longer turn on (click) the switch. I wrapped the switch with electrical tape to make it tight and prevent it from accidentally moving further into the mounting hole. Also there are more switch openings available. I think there are at least 3 more available for me after installing these 2. The wiring is also longer with the AOB switch.
