Krayziekid
Hahaha not even close. I went to the bottom of the fender. I'll redo them tonight properly and post back. Wow I really misinterpreted those first instructions lol. Sorry about that!
Appreciate it!!
Were those measurements taken like this? Your numbers seem a bit low
Okey dokey. So here are what the actual measurements should be based on that image you sent. Keep in mind that this was definitely not level ground whatsoever. With that being said, the back looks to be sitting around 39.5" and the front around 38.5". Does that sound better lol
There really aren't any "actual" measurements, I think they are useful to compare among others 4Runners. If you browse the tire/lift thread, you'll find some members that have posted those measurements.
Although to compare among different 4Runners, it's more accurate to measure from the center of the wheel/hub versus the ground. (To rule out wheel/tire differences). I just wanted to see what you're was.
In the pic I posted, my measurements are about 37.5" in the rear and 37.2" in the front.
where do you go to school? definitely wanna meet up with a fellow CT member!
I'm actually down in MD during most of the year for school, but I currently bum around Southwestern CT, kinda near Brookfield if you know where that is.
i do know the brookfield area, I'm from MD so small world!
Have been so swamped with work and school recently that I haven't been able to do any actual work on my car. I have my CB ready to go, and just today I got the final piece for my Stealth LED Bar. Here are some pics of the brackets and a little teaser of the light bar!
I ended up going with an Opt7 bar. From my research, people seemed to have pretty good luck with them and it wasn't going to cost me an arm and a leg. I actually found it was cheaper to buy it directly from them with the wiring harness, so I did just that. The harness looks well made, the bar feels like a tank, and I am so excited to install it (hopefully this weekend!).
is this the led bracket for the group buy? I'm looking to order these brackets and i think i may copy your idea with the led bar as well. But didn't it say the brackets would only fit a 30" bar?
Yea it is from the group buy from [MENTION=93512]MojaveMadMan[/MENTION]. I think he is out of stealth brackets, but if there is enough interest I am sure he would make more.
And yup, 30" bar. Technically it is a 32" bar because there are few actual 30" bars. One of the reasons I chose the OPT7 32" bar was because it was relatively cheap, and the other reason was because apparently it is the bar that the bracket is based off of.
