WEEKEND UPDATE 248,100
This happened on Saturday
Installed my 4XI front bumper
Prepped after removing the factory bumper,
-cleaned up all threads/bolts to be used
-spray pained AC drier
Spliced in the new turn signals and got hyper flash. Ordered a new LED flasher from Amazon
https://a.co/d/9YtUEnZ
Few tricks to installing the new flasher relay
I found this thread that helped but ended up removing the interior fuse panel and tilting it forward
This is where the flasher relay is
Remove and you will notice a base clipped onto the relay
Remove the base and you will see a center pin "flipper" that reverses the polarity of the relay
I tried installing the new LED flasher relay but nothing happened. Guess I need the polarity flip.
Remove the polarity flipper carefully, note there is a spring fit that snaps into a hole in the leg of the relay, you need to remove the tension here and then slide the flipper adapter up
I then slid the flipper adapter onto the LED flasher relay
I installed the LED flasher into the fuse block and tested blinkers and hazard lights. They all work and no more hyper flash!
Reinstalled the fuse block, tested everything again before reinstalling all the trim.
Note: the flasher I got clicks a few times after the turn signal is cancelled although the lights don't continue flashing. Not a big deal, it's just a little annoying.
Next up, fog light install in the new bumper.
I already modified my fog light relay per this post (
Toyota 4Runner Highlander Electrical Modifications Fog Light Mod ) and installed the proper headlight dimmer switch PN 84140-20560
-my SR5 was prewired for fogs but didn't have the correct switch, relay or actual.fog lights
After that, winch install and electrical updates
Here is how she sits today
Did a run on Sunday to Rowher Flat OHV park, here's a post pic of the group
The truck soaked up everything I threw it at with no problem. I barely needed 4WD but I made sure to get it into 4Lo and use the e-locker once. Flawless.
