odd brake light issue
kelali
05 SE 4x4 w/36k miles
The top brake light works but the but the two tails don't
the lights work fine when running lights are on. I pulled the bulbs and both dual filaments look fine.
I don't think it's a brake light switch issue as the top bar light works.
Do the tails run on a different fuse than the top bar?
Thanks in advance.. curious to know how everything is wired as I don't have a manual
I checked the 10A in the engine bay for STOP - fuse is fine, when I pulled it the 3rd brake light stopped working, when it worked before
The TAIL in the knee kick panel is fine, when pulled none of the rear lights work
Is there anything else in the brake light system, aside from the two fuses and the brake light switch under the pedal?
Thanks :violin:
patnewton
