wbp24runner
Hi guys,
I recently failed the safety inspection because my fog lights were out (these are the standard fog lights on a 2000 Toyota 4Runner Limited Edition model).
I thought, "This is an easy do-it-yourself (DIY) project". Well, I bought two new H3 55-watt bulbs and installed them, but no lights. So I got a multimeter and confirmed that no voltage was being supplied to either fog light. After reading a few posts here on the forum, I switched out the fog-relay with another identical relay, but still, no lights.
Any ideas?
I'm pretty sure the driver-side and passenger-side fog light wiring is in parallel because (1) I've had only one fog light go out before and (2) I didn't see +12V on either side when I checked with the multimeter. The lack of +12V makes me think there is a common problem somewhere else in supplying voltage to both fog lights.
Also, just to be thorough in my post, the driver-side housing must have gotten water in it, because it was very corroded inside.
So to sum up: The bulbs are good and the relay under the hood appears good; the wiring on the driver-side looks good, but could be suspect because of some corrosion. I don't know what else to check. Any ideas?
Any ideas?
