OEM Looking 5th Gen NAV Info Thread
Astrium GEE-1715
The Astrium has an optional TPMS that I ordered. It includes the 4 tire transmitters and the receiver that you plug in the back of the radio. I had 4 new Michelin tires and the new transmitters installed and hooked the receiver in the back of the radio however when I click on the TPMS icon the radio says NO DEVICE. I did not know my 2011 4runner had the TPMS already. I have had the truck for 4 years and the system never activated. If I can't get the Austium working I will have to go back to Costco to have my old transmitters installed.
does anyone know if this work for the 14 and 15? thanks
because it uses the entire dash bezel, I suspect it does not. UNLESS the center dash is interchangeable in the two versions. I know the plugs have not changed.
Did you ever find an answer to your question?
Do the factory steering wheel controls work? I don't use them often, in the past its just bothered me to have a bunch of dead buttons on the wheel for my aftermarket head unit.
Love the factory look of it though. Do any other aftermarket units work with the steering wheel controls?
Sorry for the old bump, but I just picked up a used 2013 T4R with the Rosen unit (not sure of the model number, please let me know if you do) and all the steering wheel controls seem to work fine.
Are you sure it a Rosen and not an Astrum?
Just an FYI, if you dont like the non matching knobs, you can order this part number 90010-26010 (x2) and make the knobs match the rest of the knobs.
Factory GPS question
I read through the thread but maybe I misunderestimated something in there...
I'm looking at this unit (since I bricked my unit trying to upgrade Entune, dealer visit still pending) and everything looks great (steering wheel, BT, etc) but I don't want to run wires to my factory backup camera or factory GPS antenna. I think you mentioned that you were buying a backup camera for a later add but did you say that one of the provided cables uses the factory backup camera if your truck has one?
And regarding the GPS antenna you mentioned in the front part of the dash vs the sharkfin, do you have to use the antenna provided to interface with the nav software or will the factory sharkfin (or other) simply plug-n-play? If you know, based on your install and truck etc.
Thanks for any help, and for the thread. Very helpful!!
seltzernator
