Anyone want to post info on driving in snow?
Very great information for me, someone who is interested in eventually doing some off-roading. Anyone want to post info on driving in snow?
OK I learned the hard way and here is some of what I learned:
1. It doesn't matter how capable the vehicle is, driver error can cause problems.
2. Walk the area first before you drive it. Although the snow all looked the same I had the driver wheels on hard ground and the passenger wheels on compacted snow. All 4 tires were spinning in 4-LO with diff-lock. So the ATRAC was trying to help but not enough traction anywhere. Shovelling under the skidplates only caused the passenger side to sink lower.
3. Not being careful can be expensive. $90 for the towing bill.
I know it doesn't look like it's that stuck but believe me it was!
Some people offered to help pull it out but no one really was confident with it so we decided to pay the tow bill and get it out professionally rather than have a chain snap and break a tailgate window or something.
I learned this in a 2wd truck but it wokrs with unlocked 4wd trucks as well. if you come to a point where a rear spinning tire is keeping you stuck, try using the e-brake 1 click at a time with steady increase until the other wheel gets power. it doea wear your rear pads fast but in an emergency its a life saver.
ive done that before. it actually allowed me to make it up a climb I never should have been able to. it was crazy.
I thought of something recently, and more along an extreme situation.
to use logs/limbs in place of straps or chains.
im thinking more if you're trying to use a high lift or come-a-long to get unstuck, but don't have enough cable to reach a good tree.
you could find a length of tree or branch, and using your belt, shoe laces, rope or whatever else you may have to secure it. it might be JUST enough to get you out the that predicament.
I once used several lengths of chain, and a couple small trees as levers to pull my truck out. not in the way I was describing above, as I had no mechanical pulling devices, nor any other vehicles. it was some full on MacGyver shit...
Are you saying that you use a small tree or branches as a catapult....? In that you bend them down, tie them up to the truck and let go of the branches and then the pull back force of the branches might give you just enough of a tug to help you along. Interesting.
this is crude, and the distances arent to scale, but I think you get the idea.
That could work - you'd want the short side of each log closer to the truck for maximum leverage.
yes, it DID work.
