Catahoulabulldog
Member
Anyone out there use the Bilstein 5100’s for off roading? If so what’s your set up and what kind of off roading? Thanks.
Anyone pair Dobinson springs with their 5100’s?
Although I will also note that the setting you have it impacts it as well, if you have it set at 0 with a spring lift you’ll do better than setting it at the 0.85, 1.75, 2.25 clip settings - those will compress the spring more and make it more harsh and so if you use the 5100s as your lift without taller springs you’ll get a worse ride and lose travel for the front at least
This is not true. The springs are only compressed more in full extension. With load on them, they will compress the same amount for the same load regardless of the clip ring setting.
The spring doesn't compress more, it's perch just sits higher, the truck moves up accordingly so there is no more increased compression the spring. I am on the 3rd perch with stock springs and I would almost describe the ride as plush with zero harshness.
Question regarding the 5100’s. Back in August I installed 5100’s on front and have it set on first notch (0.85) to make it more level with the rear. When doing that we took out the XRES suspension so you can imagine how rough it rides in the rear. I’m planning on installing 5100’s in the rear but I also want to add around 1 inch lift on the front and rear and keep it level.
My question is should I install the 5100’s and raise the front and rear to add 1 inch or look at installing lift springs? a spacer with the 5100’s at lowest setting 0”? Keep in mine I will not be doing much off reading and it’s my DD so I’m mainly going for looks and ride comfort.
I can first-hand attest that the spring is significantly more compressed as you go up in perch settings. I don't see how you would anticipate the spring not to compress any more by increasing the perch from the 0 perch to the 3 other available settings. The shock can only extend out so much, and believe me, it is fully extended regardless of the perch setting you have when it is out of the truck and on the work bench.
By going up a perch setting you are pre-loading the spring more and more, therefor increasing the rideheight using each of the increasing perch settings.
I am running the 5100 shocks front and rear along with the OME heavy springs. Since the kit I bought was advertised as a "3in lift kit" with no documentation, I figured that I needed to set the perch setting to the highest setting. Boy was I wrong. I ended up with damn near 5 inches of lift, carolina squat, and blow out cv boots after 25 miles.
I can tell you that at the last perch setting, I couldn't get my spring compression tool out from within the spring coils, I had to grind it and jerry rid some external spring compression devices to get the compression forks out. This was NOT the case once I switched to the #1 perch setting which dropped me to a true 3" lift, I was able to take the compression tool in and out of the coils with 0 issues. So yes, the perch settings definitely pre-compress the spring more as you guys up in settings.
With regards to my set up, again, Bilstein 5100 front and rear on OEM heavy springs, JBA UCA, 1" body lift, 35x12.5" tires. No lockers or re-gearing at the moment but the 2 trail rides I've done locally it has done OK on. Just about as much as you can expect for an entry level lift kit for under 900 bucks.
I don't expect them to last a very long time with all the additional weight, larger tires and heavy trail use and will more than likely be upgrading to either the fox 2.0, king or Icon suspension, but haven't decided yet.
The street-driven performance seems decent. Obviously stiffer than stock a bit, but feels good.
So the general analogy used is like if you set the spring on the ground and put a 50 pound weight on it, vs if you put the the spring on a cinder block and a 50 pound weight - the spring will compress the same amount whether its on the ground or is "lifted" up on a cinder block. So once you mount the coil over the spring will de-compress to its natural preload/ extension. (You have to compress the spring to get it on the coil over and mount, but once on the truck itll extend)
So this is true with a sold axle and a perfectly perpendicular lay out
- but as you point out (and I think it has to do the with the independent suspension) the ride will be different with different settings
