Official Bay Area MOD/MEET/GREET Thread
Yeah sounds good to me too.
I’ll be leaving Napa at 8:30ish
If all goes well with my son (when he wakes up and finishes eating breakfast.)
I used to work in that area where [MENTION=15034]4reak[/MENTION]show and I are meeting so it’ll take me 25-30min with traffic to get there. [MENTION=120071]mtbtim[/MENTION] Sean text me yesterday and asked me to bring a table so I’ll be taking that.
Sounds good. Keep us updated if the timeline doesn’t work out. I know how kids can be haha. I have a 3 year old.
We will probably be leaving there at around 10:15-10:20
Today is the DAY! TRUCK YEAH!
See all you fellers real soon. Come hungry because I've got shit loads of artery clogging stuff for you.
Sic Mods!
[MENTION=34852]crazydubman[/MENTION] [MENTION=47554]t4r4life[/MENTION] currently at in and out off hopyard. Ahead of schedule. See you guys soon
Unfortunately I won't be able to make it today, having a dental emergency. Todd should be there soon.
Thanks [MENTION=120071]mtbtim[/MENTION] and [MENTION=102606]infamousRNR[/MENTION] for a hell of a good day. Quite the turnout. A lot of cool ass trucks and cool ass people. Can't remember everyone's name, but it was very very fun meeting and bullshitting for the day.
Just got home from a fun day at Timmys. Had had a great time with lots of really cool people and their trucks with sick mods. It is hard to believe that people came from as far as Yreka and LA to be there, but I can understand why. Thanks again to [MENTION=120071]mtbtim[/MENTION], [MENTION=102606]infamousRNR[/MENTION], Alison, and Hobbes for putting this on. :thumb:
One of my goals for these parties is to not get too wrapped up in a repair or mod so I could have time to walk around, talk to people, and see all the cool rigs and modifications they've done. We got Wei's transmission filter job done pretty quick and Jax's rear springs and shocks done pretty quick as well. Then Chris shows up with a destroyed passenger side rear axle bearing and I knew this wasn't going to be a quick fix. The first hurdle was getting the brake drum off and I can't say for sure if emergency repair team messed up or not but big hammers and pry bars came out the drum gets destroyed in the process along with some of the brake hardware.
I had an extra axle but not the needed brake hardware. So we send Chris off with his friend to a local PickNPull and he luckily grabs a complete passenger side axle with the brake drum and hardware. The brake backing plate is really bent so we'll have to swap over the one on his original axle. I told him we may as well do the job right so I sent him to Toyota to get a new axle seal, new bearing, new dust seal, new o-ring and new retaining clip. Since we pull the parts off, we're able to reuse the ABS tone rings and retainers.
Long story short, we get everything pressed onto the used axle and he just uses the brake shoes and hardware that was on the used axle. After a few rounds of bleeding the brakes, the brake pedal still feels a little soft and we attributed it to the passenger side shoes not being adjusted enough. We pulled the parking brake over and over again to try to get the self-adjuster to tighten it up a bit more but the end result was brakes that were working, but pedal travel was a little more than normal. Hopefully Chris sees this post because I'd like to hear he made it back to Auburn safely.
Safe to say, Chris needs to buy new brake shoes and most likely either resurface the drums or replace them. And, that driver side axle seal is probably not too far behind from failing so another axle seal job is going to be needed as well. The inside of the axle housing got some good gouges in it but it's not going to affect anything. His ABS sensor got cheese grated too and that's another thing he'll have to replace.
It's not too common a rear axle bearing implodes the way Chris' did. My theory is his rear axle seal was leaking for a long time. When gear oil surrounds the bearing, it gets inside and slowly washes out the grease. Bearings need grease for proper lubrication, not gear oil. So with a compromised bearing, he gets into a long drive from Auburn to San Jose. The bearing finally overheats and it's Game Over Man.
In usual party fashion, there were fewer people in attendance than expected but that's always the case. However, this was our best showing ever and there were some really sweet rigs parked at my place. Sean will put together a party video for Y'all to check out.
Anyway, it's always lots of work throwing these parties but I like this T4R community we've got so I reckon we'll keep doing it. We will throw another one before the end of the year, most likely in the Fall. Peace out!
Tim you came through in the clutch HUGE for Chris and should receive MUCH good Karma coming your way my friend.... The hours and sweat you yourself put into the assist was amazing as always. But do let it be said for the benefit of those that weren't there; you were not on deck at the moment the drum was destroyed coming off... That was a sound we all heard while standing out in the driveway when you were taking a breather. That element should not be confused with your stellar work and commitment to help rescue a would be stranded 4Runner far from home... Outstanding once again Tim thanks for being the amazing host that you are. Allison too for putting up with all of us lol...
....The first hurdle was getting the brake drum off and I can't say for sure if emergency repair team messed up or not but big hammers and pry bars came out the drum gets destroyed in the process along with some of the brake hardware.
Timmy, you are the MAN. I've seen shop's that aren't even as well prep'd as your garage is.
As for the drum, Poor Chris and his bud was trying to get the drum off. It ended up binding, and the removal bolts cracked the drum. :-( At that point, I started tinkering with it and prying a bit. That's when the spring for the rear brake shoe dropped out. I then knew why the drum was binding. There was no way of getting things apart without either destroying the drum or backing plate, and the brake hardware. Since the drum was already cracked, that was a simple decision. I guess the luck part, is parts for the 3rd gens are everywhere still!
Tim, I've NEVER seen someone do an axle as quick and easy as you made it look. Great job man! Glad Chris and buds made it back home!
Good times are always had at the Timmy the Toolman Studios.
Check out the video I put together of the festivities for the 3rd Mod Day we've had so far. More to come!
<iframe width="560" height="315" src="https://www.youtube.com/embed/UWYkWZ0EDd0" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Dude! nice job! whos the guy with the Trekker.... :(
I MISSS TRIXXIE!
Pismo Beach Wheeling Weekend June 22-24
Hey Dudes,
Instead of trying to remember everyone to invite, I figured I'd just post it here. A bunch of SoCal 3rd Gen enthusiasts are going to be in Pismo Beach Friday June 22nd through Sunday June 24th for some wheeling, camping, BBQing and Drinking and I figured some of us could show up and represent NorCal.
The plan is to drive down Friday, camp Friday and Saturday nights and leave sometime Sunday back home. We could all camp in the same general area, do some fun wheeling followed by BBQing, Drinking and whatever else we can think of.
Let me know if you're interested.
Hey Dudes,
[MENTION=127339]4Reak Show[/MENTION], [MENTION=166333]thenightman[/MENTION], [MENTION=175921]TonyB66[/MENTION], [MENTION=126883]Diezel[/MENTION], [MENTION=34852]crazydubman[/MENTION], [MENTION=129593]MTN4RNR[/MENTION], [MENTION=53337]SCRunner12[/MENTION], [MENTION=144150]edough[/MENTION], [MENTION=81106]Cytronus[/MENTION], [MENTION=47794]Aznwolf118[/MENTION], [MENTION=98597]Jayjayb96[/MENTION], [MENTION=113939]JerkyDrewster[/MENTION], @ltsr, [MENTION=142071]sunsetrunner[/MENTION]
I know there's others I'm forgetting and I apologize if I missed tagging you for this.
Doing a little Dune wheeling, camping and hanging out sounds like fun. Come join us at Pismo Beach if you'd like.
Thanks Tim.
The wife and oldest left a few days ago for Asia, and will be gone a little over month. Great you say, time-wise? I have the little one with me, lol. Mr. Mom until mid-July. She's with the grandparents this weekend, thankfully, thus my wrenching. If I can swing-it, I'll let you know. Thanks for the inclusion!
Thanks Tim.
Ok Tony, Hope you can make it. If not, we'll jump a dune for you while drinking a beer.
Hey there Tm. Unfortunately I will not be able to make this trips have a couple things going on in the bay that Weekend.
Have fun though and will have to try to catch the next one
