Official Classics Lift and Tire thread
Footofgod
I looked, but could not find one. If there is a thread already, point me to it and I will move my stuff there. If not, I think we should sticky an "official" thread to consolidate all the lift info in to one thread, just for the classic section. (All the other gens have their own, I am feeling left out.)
Here is the SS Minnow on 33" BFG Mud Terrain KM's lifted by the OME 2" kit with ball joint spacers from Toytec up front.
001-4.jpg~original
1987 SR5 Bissonsaurus. 22RE. Auto. Double top shift transfercasess. CroMo Low gear set. Homemade CV driveshafts: Front is square tube; the rear is stock Frankenstein with long travel slip joint. Home made or Bud built cross member and skid plate ( I don't remember which truck has which). Home built Solid axle swap. 52 inch leaf springs. Yukon Gear lockers. CroMo axle shafts. Lower gears (don't remember ratio). Home made front and rear bumpers. Homemade roll cage (EVERYONE RUN). 4 point racecar seatbelts. 35/12.50 R 15 Bajaclaws on 15 /10 rims. Spidertrax spacers on front. some long shock absorbers and a steering stabilizer.... About a hundred pounds of welding wire....
Great thread Idea.
87 4runner. No lift, upper bumpstops trimmed, swaybar removed on 31s
66104_1688738345757_1456664681_1732658_3066076_n.jpg~original
232323232%7Ffp%3B4%3B%3Enu%3D46%3A%3B%3E3%3B6%3E259%3EWSNRCG%3D34%3C9%3C3877%3A335nu0mrj~original
P5201091.jpg~original
92 "2nd gen" No lift, upper bumpstops and swaybar removed, 2-3" fender trim, semi-tubed firewall, on Pro-comp M/Ts 35s
temporary-54.jpg~original
temporary-60.jpg~original
P5261102.jpg~original
P5261103.jpg~original
Stuffed with the wheel straight, no rubbing
P5261108.jpg~original
Stuffed with the wheel turned, just barely rubs
P5261107.jpg~original
Stuffed turning in, also just barley touches, but its smooth so its not hurting anything.
I vote to sticky.
I'll play!
Most guys here know what runner is mine but for those that don't, it's the superior gray one in front of the red hooptie :D
Lift is a front end of a Rough Country bracket lift which is about 4", the torsion bars have been relaxed a bit to lower it a little so it's probably about 3". The rear is a trail-gear 4" lift with the spring packs bas****ized to lower the rear and soften the ride so it's probably about a 3" lift. Tires are 35x12.5 KM2's.
045.jpg~original
Nancy says that you guys need a 7 day ban....lol
here is one of the HULK 4 inch super lift, all spring sitting on 34x10.50x15 TSL swampers with Interco Hole shot wheels. with 22re powered 4.56 gears M/T
And here is a the Snowcamp. 5 inch super lift soft ride all spring lift sitting on 315x80x16 Dunlap mud rovers that are toast! powered by 2L toyota diesel engine soon to be a 2LTurbo diesel
i had this stickied then realized people may not see it, so we will leave it in regular threads for a week then ill stick it again.
My 89 has 4 inch rough country in front, torsion bars cranked down, 3 inch body (soon to be less), and 2 inch extended shackles in the rear. My tires are 35-12.5-15 Kumho Road Venture MT's.
pinger_882180454.jpg~original
4rr.jpg~original
I'll post up once I get home. But please nancy don't hurt us!!!!! Some of us wouldn't survive those seven days!!:thumb3:
1994 4Runner 3.0L 5-spd on a 2in OME lift on 30's at the moment
Mine has a 4" rough country + add-a-leaf and tbar crank (2-3")+ 1" bl for around 7" or 8" of lift. I run 36x15.5 Baja ATZ on 15x10 Rims with a nice amount of room for flexibility. You don't need as much lift as I do to clear 36x12.5's... mine are just stupid wide and leave me less room to turn.
Nice thread btw, I was looking for something like this a few years ago.
Here's my current set up.
Front
Blazeland Long Travel Kit
Bilstein Shocks
OME steering damper
Stock Torsion Bars
Low Profile Compression BumpStops
Rear
Stock Leaf Springs
99 4runner rear coil spring (ZUK Mod)
OME Shocks
Tires
15x8 ~3.75 BS
32x11.5x15 BFG AT
1D080ABA-4337-48CC-A4F7-D4205CA9F11E-8480-0000093077081D74.jpg~original
64CEFEA7-0F8B-4C82-9B02-2A0A0952E0A7-8480-00000930F504EE12.jpg~original
A5156B92-BFC4-4750-8B77-8005302B3794-8480-0000093139AFBBD5.jpg~original
e29473f1.jpg~original
48fed1a1.jpg~original
f057f4d2.jpg~original
Front
Bilstein Shocks
OME steering damper
Stock Torsion Bars
Rear
Stock Leaf Springs
OME Shocks
Tires
15x8 ~3.75 BS
32x11.5x15 BFG AT
Hey toyotech, if you dont mind me asking.... how much was the blaseland kit? and it is all just bolt on right? dont tell me to go google it because i couldnt find a price anywhere. and are you happy with it overall?
For those with different tastes...
Trail-Gear's 4" SAS with their flexible leaf springs all around. Added a 3" 4Crawler body lift for engine/header clearance. The shoes are 35" BFG Mud T/A's. Yeah, it's taller than I would prefer, but the flexibility of the springs helps keep it upright, allowing the wheels to stuff or droop further over obstacles (instead of tipping the truck too much). It's proven itself to be quite capable so far.
Cpn2mss
