Official home improvement/ remodel thread.
Don't forget to seal the top of your vanity. If it's anything like the marble ones I have, they come unsealed. I assume you will, but also put sealer on your shower floor. I didn't know you heated the floor too! I'm not sure how I lived so long without having heated floors. Looks good!
Looks Great!!
How did you like grouting the tumbled stone for the shower base??:cry:
Where did you get that vanity?
I'm looking for one just like that (double sinks, and drawers!) for my bathroom redo..
Thanks man. Ya. Took a lot of grout and patience. Looks great in the end though.
I got the vanity on Overstock.com. I just had to mount the sinks to the top and set the top.
This looks like it had more draws than it does. The top on each side is a shelf.
And the lower on each side has cutouts for the plumbing in them
Still adequate considering all my 3 things I use will fit on the shelf and the missus can have the rest hahaha.
Thanks man. The vanity top came sealed and ya I'm sealing the shower floor.
The heatmat is pretty sweet. $500 for the mat and programmable thermostat. Not bad. Doing the same tile and heatmat in this closet next.
The heatmat just requires its own dedicated 110 line at the panel.
Then the whole space should tie together pretty well.
Yes it does look good! I always liked the look of it!
Thanks, will have to keep my eyes open at Overstock!!
BTW - some great workmanship & planning, in this thread:
Here is my recent renovation, in our 1963 Brick Bungalow / original plaster walls restored:
- structural LVL's in basement & moved living room center wall back (2 feet)
- double crown molding, on ceiling
- baseboard is Craftsman angled profile, on 1x6 maple
- all new sub floors, PL glued & screwed down / 3/4" ply under porcelain tile and 3/8" plywood under plank floor...leaves transition, perfectly flat
- 6" wide plank Hickory T&G flooring (3/4" thick, unfinished from sawmill)...41% denser than oak
- TV mantle houses some family antiques / white oak planks, are +60 y/o and ends cut to length with my fathers old 1968 Pioneer Holiday chainsaw
- door jams, are a mix of cherry / white maple / cedar / black walnut
Beautiful work man! Looks stellar.
Got the master closet floor done this week. Just have to hang some new lights the boss likes and recover the cushions on the bench and paint it black. Need to install the thermostat for the heated floor too.
Just re did the living room roght before the holidays...
Floor to ceiling, only thing that stayed was the fireplace structure itself but I fully re pardged interior of chimney box with new fire cement (chamber coat)
B4 & after
Hidden cabinets on each side so all electronics are tucked away out of sight..
Right side has modem, router, surge protector/battery back up box, etc..
Left side is dvd storage
Ran all new wiring in wall for current and future hook ups...all 4K 3D hdmi cables
Re did the existing French doors leading into the room...stripped, painted, and waxed...
New casing, trim, hardware..
Did the same process with the mantle, and the custom built shelves
B4 & after of the floor..first attempt at a floor refinish..
Ripped up existing carpet
sanded with 36, 60, 120, 220
Stained with minwax red mahagony
3 coats of clear poly
[MENTION=135933]concrete_boots[/MENTION]. Awesome work man! I really dig the hidden doors for the electronics. Very cool and very well done man. Looks awesome!
Some recent work..
Walnut live edge slab on a metal base from scrap yard steel, c-channel, warehouse racking perhaps not certain.
Wall console/shelving/barn door hiding a murphy bed..
Mixed species panel top on 2" square x base..
Funny, I was going to ask if everyone in this thread got lazy because we haven't had a post in a while. I've been re-siding my house since the weather has gotten warmer. No need for photos of that exiting job.
Haha I was thinking the same thing ...I've been busy with work but have started to take apart 2 more rooms ...pics to come in next week or so..
Someone should start an outside yard work project thread now that its warming up a bit..
MaximussK
