OffRoadWarehouse Holiday Gift Guide / 12 Days of $aving$ !!
Happy Holidays from Off Road Warehouse we will be introducing Daily Deals that CAN ship out FAST so you can have before the Holidays for Gifts!!​
Different DEALS everyday!! If you have any suggestions please don't hesitate to ask!!​
Rigid Industries Radiance PODS​
SKU: 20200 WHITE, 20201 BLUE, 20202 RED, 20203 GREEN, 20204 YELLOW
9-15 V DC
High-Grade Aluminum
Alloy Housing and Heatsink
Mounting Brackets Included
Dedicated Wire to run Back-Lighting without Primary LEDs
IP68 Compliant – Dust / Water Ingress
High Impact Polycarbonate Lens
Complete Multi-Switch Wiring Harness Available #40300 (sold separately)
GORE® Pressure Equalizing Vent
Black Exposed Printed Circuit Board
Back-Lighting Independently Controlled
D-Series® Construction And Durability New Broad Optic
**PLEASE check with your LOCAL laws when using these lights​
Special DEAL @ $100 + Multi-Trig Harness $45.00/shipped within US. Hawaii/PR & Canada Please Inquire!!!​
Please send Email or PM to set this order up!!​
Rigid Industries Dually SPOT #20221 or FLOOD #20211​
Choose between SPOT or FLOOD!​
ORW Special Pricing $139.99/shipped within US HARNESS INCLUDED!​
Rigid Industries DOT / SAE Compliant Fog Light Set​
Special Pricing $239.99/shipped within US HARNESS INCLUDED!​
ADD: Rigid Bracket kit for 2014-2016 $60/shipped with ANY Dually Kit
Baja Designs Fog Pocket Kit with Plug-n-Play Harness kit​
Fog Pocket Kit allows you to mount 2 Squadron-R Series auxiliary lights in the factory location. This Plug and Play kit includes two vehicle specific mounting brackets and a wiring adapter, allowing you to use your factory switch and mounting hardware.
587805_n.jpg~original
Baja Designs Toyota Lighting Kits (447110-587805)
2012-2016 Tacoma, 2014-2016 Tundra & 2010+ 4Runner
Brackets, Harness & Pair of 587805 Squadron-R Sport, Wide Cornering LED​
Your Special is $260.00
Baja Designs Toyota Lighting Kits (447110-587815)
Brackets, Harness & Pair of 587815 Squadron-R Sport, Wide Cornering LED (Amber)
Your Special is $270.00
Toyota 1.25" Thick Wheel Spacers​
These 1.25" thick, 6 on 5.5" 6061T6 aluminum spacers are an easy way of spacing out front and rear late model Toyota axles that run hub centric wheels (wheels use shank style lug nuts). Each kit comes with 2 wheel spacers, 12 metric M12x1.5 wheel studs (pre-installed), 12 M12x1.5 lugnuts, and Loctite. The wheel spacers are anodized in dark black, and dark blue which is a double anodizing process for twice the corrosion resistance. In addition, each wheel spacer is both wheel & hub centric for a perfect OEM fit. Proudly manufactured in the United States of America.
Fits: 1996-PRESENT 4Runner/FJ/Tacoma​
Please PM, or email [email protected] or Call us 800-341-7757​
Day 3 Stocking Stuffers!!!​
Hella Optilux ValueFit Cube 4 LED Kit 2 Light Kit - Flood Beam​
SKU: 357204831
Cube Lights, Value Fit LED Driving, Clear, 2 Lamps, 4 LEDs Each, 12 Watts, Black Aluminum Housing, Hella, Kit​
Was $159.99​
Your Cost is $74.99​
PowerAll PBJS12000R Rosso Red/Black Portable Power Bank and Car Jump Starter
  • 400 Peak Amp Jump Starter
  • Anti-Voltage Feedback Prevention
  • 12,000 mAh High Capacity Battery
  • Dual USB Charging
  • Ultra-Bright LED Flashlight
  • Portable battery charger with charging adapters for all major electronic devices
  • Compact car jump starter that can jump start your car 20 times on a full charge
  • Ultra-bright LED flash light, strobe light, and SOS signal light that lasts 120 hours
  • Built-in protection features: over current protection; short circuit protection; overload protection; over-voltage protection; over-charge protection
  • Portable compact design that will easily fit in your pocket, backpack, or glove box for convenience
Perfect and Small to keep in your car in case of a battery failure for your car/truck or personal electronic items.
Want ONE or 2? These make perfect GIFTS and can be shipped in time for Christmas!!
$69.99/shipped!!!​
PM or Call 800-341-7757 or [email protected]​
brendaglores
