Ohcrymore Build Thread
looking good with the SW!
how does the wind react with your roof rack/sunroof when its open on the road?
New developments:
- Skid plates remounted and stock frame weld nuts replaced/reinforced.
- Trailing arm frame mounts cut out and reinforced with 1/4" steel, painted.
All courtesy of Russ Jr. at American Tire in Yonkers, NY
Yet to come:
- Front drivers wheel bearing/hub replacement
- CB and HAM antenna hood mounts by CBI
- Replacement of all suspension bushings and ball joints
- More to come
Sent from my SAMSUNG-SM-G870A using Tapatalk
How did you reweld the frame nut inside the frame for the skid plates.
Russ didn't. He welded new weldnuts on the bottom of the frame for some of them. For the front crossmember (under the radiator), he fabricated a reinforcement for the crossmember, drilled through and welded nuts on top of the reinforcement he made.
So this would make the skid plates where the nut is welded stick out a little more I guess.
I drilled through end-to-end and put a long bolt right through with a nut and washer on the passenger side. If I come to grips at the idea of welding on the frame I guess I'll need to do that on the driver side since there isn't much space between the cross member and drive shaft.
Yea it does, but it's a marginal clearance decrease (1/4" or so at most). I'm just happy knowing that I won't have to fight with the bolts again when I take the skids off for the winter.
