“Oil Maintenance Required” Too Soon Issue
Honda's Maintanence Minder is a great system, unlike this Toyota one. MM actually does take other factors into affect. I followed it religiously on my old Accord. The light came on at a different mileage every time, unlike the 4Runner which is always at about 4500 miles. It's stupid with a recommended 10k interval. Granted, it's pretty easy just to reset it and move on with my day.
Why is everyone overlooking the OP's mileages for maintenance minder?
He said it came one at 4400, then 13000, then 18000. This means it does not come on every 4500 or every 5000...
This means it came on after 4400 miles, then again after 8600 miles, then after 5000 miles. Solid data, no conjecture, no assumptions..... it doesn't go off on a purely mileage based equation. If it did, it would come on at 5000, 10000, 15000, etc.
Has anyone else tracked miles traveled between oil change indicator?
The recommended interval is 10,000 miles, so I stick with that, or thereabouts. I’ve been faithful to do 3000-mile oil changes at times, and gone 15,000 miles at other times over the past 45 years. But I’ve never experienced an engine failure due to a lubrication problem. My view - stick with the manufacturer’s recommendation and don’t waste any more time on it than that.
I did the changes based on mileage not waiting to be reminded by the truck. It may have come on at the 13k interval but not at the 4.4k change.
Dude…
■ If “Oil Maintenance Required Soon” is displayed (U.S.A. only)
Indicates that all maintenance according to the driven distance on the mainte-
nance schedule* should be performed soon.
Comes on approximately 4500 miles (7200 km) after the message has been reset.
If necessary, perform maintenance. Please reset the message after the main- tenance is performed. (P. 399)
*: Refer to the separate “Scheduled Maintenance Guide” or “Owner’s Manual Supplement” for the maintenance interval applicable to your vehicle.
Page 487
https://www.toyota.com/t3Portal/document/om-s/OM35B41U/pdf/OM35B41U.pdf
“Oil Maintenance Required Soon” is just a poor choice of wording...
Exactly, however I think its worse that that. I believe it is a purposeful attempt to deceive the owner and generate income.
If you didnt have much experience with automotive you would be driving your 4R to the dealership for an unneeded oil change. It should say "Maintenance Required". My wife's Honda 2018 TLX SHAWD says that and has a codes that specifically detail what needs to be done. Oil, or Oil and Filter, Rotate tires, Change diff. oil etc. How hard would it be for Toyota to do that ? Instead the app has the same maintenance item listed several times at the same milage point. Didn't anybody bother to check it before they released it?
This wording is just another example of how Toyota creates situations with their products designed to separate the owner from their money.
A couple examples:
the craptastic windshield (there are people here that are on there 4th windshield)
$900 door handles (cannot be replaced without replacing the entire door panel)
Dude…
Page 487
Well, that answers that. Doesn’t answer why OP states 4400 miles and then 13000 miles between light. OP reset light and forgot, maybe…
The light comes on about every 5000 miles. Yes, you are right that the oil is changed every 10,000 miles, but there is an earlier maintenance at 5000 miles that mainly consists of a tire rotation, no oil change.
Drive shaft u-joints greased every 5K along with checking the infamous floor mats.
Hey, the manual does say “approximately 4500 miles”. So we were all right.
If the whack-ass'ed "Maintenance Indicator" was working like it was supposed to it should have gone on 4500 miles after the last reset at 8900 miles and I definitely do not remember it going on or resetting it then.
weird
AndiGarage
