Okki's Build Thread
Winch (Warn Zeon 10) - on site and ready for installation.
Front bumper - currently in production.
Front 30 inch Rigid - On site and ready for installation.
Rear bumper with swing out - Currently in production.
Coil over upgrade - ordered and en route.
My visit to [MENTION=64712]CBI OffRoad Fab[/MENTION] will be exciting!
Okki
Awesome! I'm heading to CBI in November for front and rear bumpers! Nathan is a great guy and they have an awesome shop. Don't forget if you have time the St. Anthony Sand Dunes are only 40 miles away. 10,000 plus acres of dune goodness! Can't wait to see pics! Safe travels.
Okki
We look forward to your install! It is going to be awesome!
Dammit, wish you hopped on our small CBI GB. Looking forward to seeing how it turns out!
My order has been with CBI for a while now. So the group buy didn't matter for me anymore. The dual swing arm was designed for pulling a trailer. The shorter arms can be opened without unhooking the trailer. It is also helpful for people who have tighter parking situations.
It's worth the premium in my mind, but the checkbook ran out:crybaby: LOL.
Okki
Okki,
Re your light install, I've studied it and plan to use your write-up to put four LED lights on my new Gobi. Question is -- with LEDs, do I still need to use relays? (Shows I know nothing about electricity!!).
Looking forward to seeing you and your new bumpers!
Sundog
Okki,
Sundog
I'm no electrical genius either, but since they are included in pretty much every light wiring harness, I see no reason to leave it out. It separates the switch from the powersource that operates your lights, so it's a safety measure within your electrical system and it allows you to do cool things like multiple sources switching the same end-point. [MENTION=83083]rigtec[/MENTION] can probably give you a much more detailed description on the why and what specifically it does, but my simple answer is; yes, you want to use the provided relay.
(At this point I usually call my brother or dad who are engineers... once they have explained it I try to complete the mod and document it before I forget all the details they provided :bravo:)
Are you going to be in the neighborhood of Idaho Falls or Teton or Yellowstone early June?
Okki
"...It separates the switch from the powersource that operates your lights, so it's a safety measure within your electrical system and it allows you to do cool things like multiple sources switching the same end-point... ...yes, you want to use the provided relay..."Okki
That explanation is spot on [MENTION=55815]Okki[/MENTION] ! The switches aren't designed to carry any substantial electrical loads e.g. 2-3 amps tops. So the switch will only be assigned the meager task of energizing a coil in the relay (fractional amperage) that will emit a small magnetic field, yet strong enough to close the contacts (completely separate circuit) that will supply the high amperage main electrical load e.g. motors, lights...etc directly from the battery! Make sense...
Best to you!
Noted and thanks! Will do as you say. Not going to be in the area when you are getting the bumpers, suggest you stay out here and come to FJ Summit mid-July for some awesome 4-wheeling.
SD
Okki
SD
LOL.. Yeah, I wish. But the PTO fund doesn't stretch that far. I guess you'll have to get with [MENTION=65398]Reata[/MENTION] and bring an "Okki" cutout to that party! :heh:
Just going to leave this here.... As I left my truck there. Can't wait to see [MENTION=64712]CBI OffRoad Fab[/MENTION] complete their handy work.
Okki
How did the Runner turn out? Dying to see pics of the new bumpers lol! Hope you had time to hit The St Anthony Dunes.
Tomorrow is the big day. Did the following :
- Hell's Half Acre Lava Field at the Blackfoot rest area.
- Craters of the Moon National Park.
* hiked the Indian Cave. Very good Ranger guided tour.
- EBR-1; nation's first commercially viable nuclear power plant.
- Shoshone Falls.
- Snake River green way.
Tomorrow we're staying in town. Doing the museum, laundry, stock up for camping at Teton and Yellowstone. And most importantly, get my baby back with the new toys on it.
Okki
Fumoto Oil Drain Valve
Fumoto F-103N Engine Oil Drain Valve $ 26.50 Amazon
Mobil 1 0W20 – 1 Quart (2 jugs) $ 15.48 Walmart
Mobil 1 0W20 – 5 Quart (1 jugs) $ 24.97 Walmart
Oil Filter $ 6.47 optional Walmart
Total $ 73.42
WHY:
With the full set of skids on the bottom of my truck now, I thought it would be easier to drain the oil by using a Fumoto valve. Being able to turn the valve lever versus having to undo and reinstall a drain plug seemed easier when working in small confines.
WHAT:
I printed out the oil change instructions from [MENTION=65614]Antman[/MENTION] here. It provides great instructions on how to remove the OEM skid access panel and all the things you need to know for a regular oil change.
I picked up the valve, oil, filter and some hose. In the final installation I left the hose off since there is enough, but not a lot of clearance between the valve and the access hole in the Shrockworks skids.
INSTALLATION:
Start by removing the access panel and place your oil drain pan under the opening. Make sure you have a pan that holds at least 7 gallons of fluid and preferably has a drain spout.
Following [MENTION=65614]Antman[/MENTION] instructions, drain the oil. Make sure you have driven the truck so the oil drains more easily.
When you remove the drain plug, it will drain immediately, so wear surgical gloves and be ready for it. If you wish to complete a full oil change, replace the filter now per the instructions linked at the start of this post.
Once drained, you can install the Fumoto valve. It simply screws in place of the drain plug.
I initially installed a piece of hose, then trimmed it back, and eventually removed it once I noticed the small clearance with the Shrockworks skids.
[A picture of the valve with the Shrockworks skids installed will be added later.]
Refill your oil at this point, run the engine briefly and check to make sure you didn’t overfill the reservoir. You should expect to use at least your 5 gallon jug.
Okki
Now you really got me thinking about ways to improve my maintenance activities.
A long post about electrical wiring and planning things out on your truck is coming, but first there are a couple things I'd like to wrap up on my truck actually! :)
Okki
Amazon had a really good deal on the OPT7 lightbars. Got a 42" for half what it cost when it was on my xmas list in 2015!
Now it's just waiting for xmas in July!
(Now is anyone interested in a set of slightly used, but well traveled Hella halogen lights? LOL)
Okki
erinobr2000
