Omegateks '02 Build Thread
omegatek
December 26th 2014
Found this gem for $6300
2002 SR5 4runner
140K miles
Lots of service records
2 owner (1st owner owned it 10 yrs and always had it dealer maintained)
Timing Belt replaced @ 80K
New 265/75R16 Wrangler Duratracs
Clean paint
No dents or dings
Leather in good condition, no rips or tears
January 17th, 2015
Items I tackled/replaced
  • replace spark plugs and wires
  • replace air filter
  • replace throttle body gasket
  • clean throttle body
  • clean MAF
  • replace upper/lower plenum gaskets
  • replace pcv valve and gasket
  • replace valve cover gaskets
Pulled her in the garage and took off the hood and grill for easier access.
These were some grimey looking spark plugs!
1st time doing any kind of hands on mechanic work, but this forum is an amazing resource and so helpful, I was able to build up the courage to tackle the job.
12 hrs later, don't judge :becky:, I was done.
Took her for a spin down the highway and she purred like a kitten!
Throttle response was definitely improved, no hesitation.
Took her to the local car wash and pressure washed all the built up oil on the firewall, skid plates, tranny, etc.... clean as a whistle.
January 19th, 2015
Really not a fan of all the green lighting, so all that green had to go! :lightsaber:
The antenna mast was broken and the motor did not work, so I replaced that and the stock head unit too.
Old broken antenna
New antenna
Next up was the dash. Went ahead and ripped apart the dash to change out the bulbs and head unit.
Gross Green
Clean White
All washed up
January 20th, 2015
Pics coming soon
Teaser for now
Next Upgrades/Mods:
  • ISR and Deck Plate Mod
  • B&M 70264 SuperCooler Automatic Transmission Cooler
  • Synthetic Transmission Fluid Flush
  • 9003/H4 CREE Ultra Bright LED Headlight Kit
  • 120 LED Dual Switch turning signals
  • LED parking lights
  • 48 SMD/LED Cargo and Dome Light
  • 16 SMD/LED Map Lights
  • 40" LED Light Bar
  • Satoshi Grill Mod (Black)
  • Plastidip emblems in black
  • Paint Rims Black
January 24th, 2015
Finally stopped raining and got a chance to put on the Curt Basket with extension. Also added the Clear Corners. Hoping to install leds in the clear corners and some dual switching leds for the bottom turning signals soon.
Next up though is the BM Transmission Cooler. But wallet is a little light after the VCG's, tuneup, radio and roof basket.
AndiGarage
