Texas05SE
Ok, guys. I've been wanting to do this for a long time and have narrowed down what I think I want. Poke holes in this plan as you see fit. The 4Runner is an '05 V8 Full-time 4wd bone stock.
First I was planning to ditch the X-REAS and go with an OME lift. I am planning to swap the wheels out for the TRD/BBS 18x9 wheels so I can avoid running spidertrax. For tires I think I'm being screwed size-wise by the spare tire space constraints. I'd like to run 285-65-18 like user "ofcbarbrady" but no chance a full size spare is fitting there. A step down from that would be 275-65-18 which user "promed" seemed to have fit in his spare location so decided to check if I could pull that off. Online tire calculators say a 275-65-18 is 1.5 inches taller than the stock 265-65-17. I measured under my truck and the spare is already against the hitch and the only space left is 1 & 3/8 of an inch between the panhard rod and the spare so I can't run 275-65-18s. After messing around with sizes it looks to me like a 285-60-18 is my best bet. It's just under one inch taller than stock and *should* fit under the truck as well since I can't run around without a full size spare running full time 4wd.
Anyway that's how I've reasoned it out OME lift, BBS/TRD 18x9 wheels with 285-60-18 tires. Questions are does the panhard rod only move vertically so I'm good on fitting the spare? Is less that half an inch of clearance to the panhard rod sufficient? Is this wheel and tire combo gonna require new UCAs?
Please confirm or deny my suspicions. I've dreamed of new bumpers with a tire carrier, but that's just not gonna happen for a long time I think so what say you?
