Ordered a "Plug and Play" Android headunit
So to sum things up, what I understand is with a basic non-JBL/RDS headunit, get the Atoto A6 Pro Toyota unit and it comes with everything you need, plug and play.
If you have JBL, then find a base console or console bracket.
Any others with feedback on the A6? Does it improve on the base headunit sound quality?
With the JBL system you also need an additional wiring harness/adapter mentioned by [MENTION=459231]xtremewlr[/MENTION] above. Just clarifying for anyone who revisits this thread in the future.
Sent from my SM-G975U using Tapatalk
Another caveat I have discovered about the non-nav JBL head unit.
Not only is the radio bezel different but so are the HVAC controls. I got a replacement radio bezel off ebay and it fits the A6Y perfectly and there are no gaps on the sides any longer. HOWEVER.... There is still a gap at the bottom because of the different HVAC controls. With the larger JBL head unit, the plastic molding at the top of the HVAC controls extends UP about 1/4" and doesn't extend BACK like the nav or non-JBL head units.
So, off to ebay to find a new HVAC control unit that will finally finish the project. I'll post pics of the difference once I have one.
Replacement climate controls received. Here are the visual differences.
Original to my 4R on the left. This fits the JBL system without nav. The right side is either a standard radio or the JBL system WITH nav. Notice the difference at the top, above the display.
And here is a comparison of the tops from the side. The non-nav fold back and over the top to fill the gap between it and the radio.
Is the top bezel removable so you can swap your old bezel to the new one?
On the climate controls? Possibly, I didn't look at that.
Looking at my original climate control, I would say yes, you can do that. It would involve disassembling the whole climate control to swap out the face, since that is one piece.
So you could buy a cheap climate control, even one that doesn't have all the same functions as your original and then swap the face on them, retaining the functionality of your current one and getting the correct face/bezel for the radio swap.
I have the non-JBL and the A6 Pro Toyota version still didn't fit perfectly because the Atoto unit sticks too far out on the stock brackets.
Interesting. I had no problems with the stock brackets from mine (JBL unit, non-nav) when I did it. All my issues were otherwise noted and resolved with factory parts off ebay.
I emailed Atoto support and they said the A6 Pro Toyota version is not compatible with the 4th gen 4Runner.
I'm really confused. I'm going to return it and go traditional name brand headunit.
Ditto. Check out this email from Atoto. Bizarre.
Sent: Tuesday, February 25, 2020 1:14 AM
To: Newton
Subject: Re: A6YTY721PR in 2004 Toyota 4runner
Dear Customer,
You bought A6YTY721PR on Feb 10, 2020.
I am afraid that A6YTY721PR is not compatible with your car.
You may purchase A6Y27 universal double din car stereos.
I can help you return A6YTY721PR. Thank you!
Oh well, I already returned it. Going to go Pioneer. Shame because the Atoto looked great.
No idea why they said that. The customer service rep I talked to via email said it would fit but not with the JBL system. After doing my homework, I found out what was needed and the differences in the JBL with and without navigation and the non-JBL systems. I curious to see what factory system you have. Do you have any pics of it installed, before you tried replacing it?
Great thread, got me thinking. I really like the idea of the android but haven't decided if I want to go to the extra trouble since I have the jbl system.
[MENTION=459231]xtremewlr[/MENTION] does your head unit do the gauges / have an app that will do the gauges like the first unit in the thread? I really want to be able to see that data, but need a unit with rca subwoofer outputs in the back...
The app is Torque. It's an Android app so yes, it does have the capability.
I have the Pro A6YTY721PR sitting in my cart at the moment and wanted to clarify a few things before I buy.
I have a 05 4runner sr5 base model with no jbl or nav. This unit will fit with no gaps, correct?
Does it have instructions on how to tie into the steering controls or is that covered with the plug and play harness they have included?
how does the audio output sound for music?
thanks all
peacefulpiranha
